Diss Member
Blasted #*$%!@§! speaker wire door grommet
Both of my door speaker wires have gone the way of the dodo and I got a great explanation of how easy they are to replace...
Of course there is a "gotcha", The wire swap went fine but now that it is done I need to get the door grommet back in. I can get a finger on one side of it both inside and outside the door. I tried using some glycerine to help it slide home. The wife tried it with smaller hands. I even tried pushing it with screwdrivers and sticks through the speaker wire hole in the body. All of it just lets me exercise my vocabulary. So does anyone know a trick to seating the door grommet?
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Diss Member
Two days and no responses...
![]() And even more shocking!!! Two days and the Pelican forum is so slow that it barely made it to page 4!!!
Been there...i think the easiest to do a proper job is to remove the door, not as bad as it sounds.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Yep, pita I'm afraid W. 😃
Done one on my SC. Worked by poking with screwdriver after much finagling... Def. Easier with door off. Cooper |
I feel your pain as I had the same problem. I managed to get mine in place with dish soap and wooden salad spoons. Takes lots of patients.
Diss Member
The "salad spoons" idea seems to be a good option. I think I'll try a dowel with a slot cut in it for the wire and run it through the inner body hole.
Also I got a PM that suggested using a hemostat to pull through from the inside which sounds doable. I'll report back with which option removes less hair.
