-   -   OMG this rust is bad - but how bad is it? (http://forums.pelicanparts.com/porsche-911-technical-forum/838553-omg-rust-bad-but-how-bad.html)
RSBob 11-14-2014 08:31 PM
If that part is so far gone, I can't imagine the house of horrors in the inner and outer longs, rear parcel shelf, and and....... I would walk away.
Lapkritis 11-14-2014 08:36 PM
What fun is there in walking away? Dive in there, chop it up and weld in new metal. ;)
irl 11-14-2014 09:26 PM
this is avery common area. it rusts out under the left dash, it can wreck a few gauge holes and most likely, beneath the pedal cluster(the pedals) it got down there too as well as the front and bottom section beneath the fender mounting. It could be not as bad elsewhere or a disaster. we need clear and more photos to help you at all and can't make decisions on one grainy close up of a very common area to rust.
RSBob 11-14-2014 10:27 PM
The way OP phrases his questions, he will more than likely have the repairs professionally done. That starts adding up to serious coin if more areas are found.
gamin 11-15-2014 04:44 AM
I wouldn't touch it. If it was a long hood, maybe.
schoward 11-15-2014 06:48 AM
No run for a long time - and electrical issues way back when too. On top of that rust. Move on. You can buy a good shape sc for what you will put into that car in first 6 months.
heimtun 11-15-2014 07:15 AM
Not the case. Just sayin'
Again, thanks to all for your input.
