-   -   removing auto heat wiring loom questions (http://forums.pelicanparts.com/porsche-911-technical-forum/839842-removing-auto-heat-wiring-loom-questions.html)
SpyderMike 11-22-2014 01:51 PM
I am backdating systems and trying to remove wiring on my 1985 targa. I removed the auto heat controls between the seats. I have the two connectors under the cardboard panel. The wires go in the tunnel and most likely forward. Has anyone successfully removed these?
Also, there is a small gauge brown/white wire running back under the ebrake mount plate. What is this wire for?
Thanks-
http://forums.pelicanparts.com/uploa...1416696704.jpg
HorstP 11-22-2014 01:59 PM
brown wire is for the red e-brake warning light in the middle of the dashboard
SpyderMike 11-22-2014 02:44 PM
Thanks, I am removing that too.
