VFR750's Avatar
Can I reglue the scavange tube into the pump?
1982 3.0 SC oil pump question.
Checking out the oil pump, and I noticed the scavange tube can wiggle just a small amount.
Can the scavange tube be reglued into the pump housing?
Does it come straight out, or is it installed from the inside of the pump body (assuming the pump is disassembled first)
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 11-24-2014, 06:01 PM
