opie's Avatar
Battery light
Just started my 86 911, noticed the batt. light stayed on, sometimes i have to rev to above idle to get it to kick off but this time did not. So checked to see how bright headlights are, no headlights. Everything else working fine. Any suggestions?
Old 11-29-2014, 11:48 AM
RETIRED
Joe Bob's Avatar
Put a meter on the battery terminals. Should be 13 ish not running, 13.5 running and 14 volts at 2500 rpms.
If not your alternator is going. As to the lights not working that could be a separate issue like fuses.
2012 ML350 3.0 Turbo Diesel
Old 11-29-2014, 12:28 PM
opie's Avatar
Ok, found the headlight problem, booth bulbs blown.(kind of a freak thing) havent figured out the batt. light yet. Seems like its charging ok.
Old 11-29-2014, 12:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Call AAA to diagnos or take the battery to a FLAPS to check the condition of the battery.
Have you done any work that required neg side to be removed? check that too.
'85 Carrera Targa
PCA/POC
RETIRED
Joe Bob's Avatar
Were you having other weird symptoms? Like the tach swinging back and forth, radio getting loud.......you could have had a voltage spike from a bad regulator.
Old 11-29-2014, 12:53 PM
DRACO A5OG's Avatar
+1, that could have caused the bulbs to blow, liken to a current surge
'85 Carrera Targa
PCA/POC
Old 11-29-2014, 12:57 PM
opie's Avatar
None of the above, just checked the voltage at the battery, 12.8(not running), then started the car, dropped to 12.2
Old 11-29-2014, 01:04 PM
RETIRED
Joe Bob's Avatar
Did it come back up when revved?
Old 11-29-2014, 01:06 PM
opie's Avatar
No it did not
Old 11-29-2014, 01:44 PM
Wer bremst verliert
JohnJL's Avatar
You likely have a problem with your regulator or alternator itself.
John
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-29-2014, 02:31 PM
sounds familiar....new alternator needed. If it's the original alt..it did good.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 11-29-2014, 02:46 PM
opie's Avatar
Thank you guys. I think its time to replace the alternator.
Old 11-29-2014, 03:44 PM
