Money no object, which panels: steel, FG or CF?
Like the title says, if initial cost was not a determining factor, what panel material would you choose if you were changing fenders, hood, bumpers and decklid for any reason on a street car? Assume that long term durability is more important then weight savings. I want to paint it once, not every year.
My gut feeling says steel, but if properly made carbon fiber is as good then it may be worth a look. Some have commented that the weave eventually shows through, is this true or only on poor quality pieces? Finally, I came across an old post by TRE... they know FG and even so it sounds like a nightmare. (Note that I'm not saying anything negative about any manufacturer, just sharing info that I think is relevant here.) Post pics of Carrera RS replicas here...
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. Last edited by evan9eleven; 11-10-2014 at 12:59 PM.. |
"if initial cost was not a determining factor"
".... for any reason on a street car?" CF |
if steel parts are available, steel. If the bumper/wing/skirts/whatever you want are simply not available in metal, CF
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
E-85 sippin drunk
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Skunk works
Cf
964 RS-4 |
Aluminum
Steel. For strength and safety on the street.
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
I'll race for food
CF no question about it. steel second
Radu '82 SC black on black "The Beauty" 3.8 RSR GT2 track/street "The Beast" www.octanegallery.com |
If weight is not important and long term durability is.
Use steel!
'66 3.2 "Blue Car" '73 3.0 "Orange Car" '78 3.2 "Brown Car" |
Do the CF parts fit better than the FG parts? The steel is so nice it basically bolts on a fits, save a lot of time and potential for problems
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Aero devices made of steel. Really? That's beyond retro.
Review the OP's parameters, then imagine you're chief engineer with Porsche, Ferrari, Audi, Peugeot, etc., even GM and Ford. If you select steel, you'd be assigned to the vintage design dept. MHO, Sherwood |
Thanks for the replies. Sounds like good old steel is a no-brainer for fit and durability, though lots of votes for CF and it wouldn't hurt to lose some weight. No one said FG, so thats out! One thing is decided, the rear bumper parts (plural) will definitely be steel when I get this project going. Anyone know if there are early bumper corners that mate up to SC flares? Drives me nuts to see molded bumperettes in body color on a backdate.
![]() I think I've looked at just about everyone that sells these parts, but I'll gladly receive recommendations for suppliers. Please: only parts you have direct experience with. Thanks!
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
I went with steel rear flares. I felt that from a resale point people would value properly butt welded steel flares. It was a lot of work.
On the front I went the easy route and just bought fiberglass flared fenders from MA Shaw. They bolted right on with no tweaking. If I were to do it again I might just buy full carbon fibre rear quarters from MA Shaw/ Getty |
![]() FWIW, I'm good with beyond retro vintage, but if there is really good CF out there I want to know about it. Except for the rear bumper as mentioned above. I wonder where the Bugatti design chief got his CF panels for his backdate? I don't think he's a compromise kind of guy. Bugatti Head of Design's Personal 911 Project - /DRIVEN - YouTube Edit: I'm not building a lightweight though...
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. Last edited by evan9eleven; 11-11-2014 at 10:40 AM.. |
He used Kevlar panels
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
If your a composites guy, and want a factory level of fit and finish, none of the fiberglass or CF parts from the normal suppliers Getty/MA Shaw, GT Racing etc. are of that grade. Generally they pay more attention to the layup when you order the CF version of the part but they are still a wet layup, usually with a considerable amount of glass mat and polyester resin built in the same mold as the fiberglass version of the part.
For highend structural carbon parts constructed in a way that fully take advantage of the material with epoxy resin, a vacuum bagged or resin infused process and a quality core material if the part warrents it, built to the level of an OE part or what Singer uses will require going to a boutique manufacture such as CarbonArt or WEVO or a number of others at a price double or more then that of any of the more common bodywork suppliers. For this reason on a street car any composite work is generally frowned upon because barring a few highend exceptions, they do not have the fit and finish or durability of steel parts. To make and instal composite parts at a level that elevates it over steel is a very expensive proposition. |
Yes, thats true, I wrote CF by mistake. Bet that wasn't cheap.
"if initial cost was not a determining factor" and ".... for any reason on a street car?" It seems you're interjecting personal opinions which, in fact, may not be generally accepted; e.g. "any composite work is generally frowned upon ..... ". Everything is a trade off between fit, finish, weight, cost, application, aero efficiency, cost, availability, ease of repair/installation/coating application, maintenance, longevity, etc. YMMV. As for metal body panels, I would generally accept aluminum over steel for my ride. Porsche continues to weigh the pros and cons of possible materials and don't seem to be too hung up on steel. MHO. Sherwood |
What impressed me about the Getty / MA shaw parts is that they use a higher tech two sided molding process.
Incredible parts compared to other products that I have seen. |
