Zack
car-nut's Avatar
Security /alarm system
Hello!
In my relatively recently purchased 86 911, there is a Security Products Inc. (model CS8801 SE), with its picture in below. The car did not come with any remote for this system. However, when I lock the doors, it become activated. I have already contacted the "Security Products Inc."; however, I was wondering if any one of you folks have such a system in his/her car.
Regards,
Zack
The car-nut!
2007 Porsche Cayman-S
1982/86 wide-body 911 Carrera
1959 Triumph TR3
2004 Harley Davidson Deuce
Old 12-01-2014, 06:09 AM
88 Carrera, Guards Red
azhodge's Avatar
the manual is on line, just google it. remotes are also still available.
Old 12-08-2014, 07:44 PM
T77911S's Avatar
aftermarket car alarms really suck. they cause more problems than they are worth. (i did auto electric work on cars for a little while.)
the big problem with our cars is they usually splice into the already weak starting circuit. the start wire from the ignition switch to the starter is vey long and a lot of current is needed to pull in the solenoid. adding in connectors (usually cheap) and a relay adds resistance and can cause starting problems.
what i would do if i HAD to have an alarm is to put the start wiring back to original and just leave the alarm portion. but if you need to disable the car do it with the fuel pump circuit or the DME relay.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-09-2014, 04:38 AM
