universeman's Avatar
Removing an aftermarket dash pad cover?
Team:
I have a squeaky brown aftermarket dash which is about 80% OK but about 20% infuriating (squeaks, warps, lack of fit, etc.)
I'm considering it removing and revealing the horrors likely to be below on the original dash pad.
I've tugged at it a few times but it seems to be locked in place hard, though no visible attachments or screw heads etc. Could be glue but I'm nervous about making a mess if I really pull hard.
Any advice on how to get this thing out and get back to basics?
Old 12-03-2014, 09:32 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Windshield and seal needs to be removed. Sorry :-(
'85 Carrera Targa
PCA/POC
Old 12-03-2014, 10:46 AM
Originally Posted by universeman View Post
Team:
If it's a hard plastic cover, they were designed to be glued on with silicone cement, usually supplied with the product. That's probably the resistance you are feeling.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-03-2014, 11:00 AM
TheSt|G's Avatar
Generally not for the covers.
First thing I did when I got my car was pull the horid dash cover, expecting it to be terrible undernearth. To my suprise, there was just one small crack on an otherwise perfect dash. No idea what the PO was thinking.
Most of the project since has been removing all the silicone caulk.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 12-03-2014, 11:39 AM
