The rubber molding on the driver's door sill came off while I was putting a wheelskin on my steering wheel. It had come loose during a New Orleans heat wave.
What kind of adhesive should I use to reinstall it? Any suggestion re how to clean it. Frank '77 Targa |
Adhesive
Had the same problem. Used 3M Weatherstrip Adhesive (Black)
P/N 051135 08011. Got it at NAPA. Works great. |
Schleprock
You can also use double-sided tape. That's how a new door sill rubber part is fastened from the factory.
Kevin L '86 Carrera "Larry" |
Non Compos Mentis
By reading the title of this post, I thought there would be about 57 replys in ten minutes before the whole thing got deleted.
I'm not even going to comment.
Are you supposed to use adhesive?
-- Curt
Perhaps you need to try a smaller one? LMAO
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
I'd try a new one rather than a used one, but that's just me.
As for adhesive.......
Jeff Randall '90 Carrera 4 '79 911SC PCA NW Region Member SCWDP Member - Muhahahahaha |
