Which SSI hardware? Plz help :)
Guys,
I recently purchased a set of SSI's for my 79 3.0. Can someone please help me with which head to ssi gaskets I need? There appear to be a few different ones: 930-111-191-13-M30 and 930-111-191-13-M17 Also --- I assume these are the nuts that I should get to replace the old ones that hooked up the stock heat exchangers to the heads? 999-084-052-02-M260 Aaaaand… this is the muffler gasket? yes? 911-111-191-02-M17 Thanks! Paul |
Anyone?
Your numbers look correct to me based on this UK site I used for reference when I fitted ssi's to my 3.4.
http://www.type911shop.co.uk/shop/category_71/Fittings-_-Heating.html?sessid=59c5FYVyMvAQNjL3SOUZWBUJifWDro XAayMAPCHytkurZAxyn6LJTL71hS6dTzyJ&shop_param=cid% 3D%26 |
Excellent! Thanks!
Regards, Paul |
I suggest using this link to confirm part numbers.
Porsche Original Parts Catalogue - Parts and Diagnostic Information - Porsche Service - Dr. Ing. h.c. F. Porsche AG Sherwood |
Y'know, in searching Pelican's offerings on gaskets for your application, I recall 25 years ago having the same question. Do you buy a gasket for the year engine that you have, or do you buy the pre-1974 gasket to match the SSIs? As I recall, I did the latter.
Brian |
Guys,
Finally getting around to this --- Do these nuts 999-084-052-02-M260 replace the old 8mm socket type of nut 999-085-001-02? Looks like I have the socket type on my SC right now. Let me know what your thoughts are! Regards, Paul |
Not sure mechanical lock nuts are needed here. Nature has its way of locking these in place. :) YMMV.
At any rate, to stave off corrosion from future road muck, I suggest covering threads and fastener with anti-seize compound, before and after installing the nut. The socket-head nuts are factory and allow hex driver access through the HE, but not necessarily required if you can otherwise access them with the right wrench/tool. Sherwood BTW, the PParts description is a little confusing, "M8-13". M8 is the threaded shank OD, usually followed by the thread pitch; exhaust studs and other 911 fasteners are commonly used M8-1.25. The "13" probably refers to the wrench size for the hex nut. However, 12mm wrench-size M8 nuts are sometimes recommended to allow better tool access in that area as are nuts made of copper in either size for increased corrosion resistance. |
So in other words I can replace the existing hex "nuts" with normal locking nuts with locking nylon…. correct? Thanks, Paul |
For example: http://forums.pelicanparts.com/uploa...1424642386.jpg Sherwood |
| All times are GMT -8. The time now is 10:34 AM. |
