Send a message via AIM to sempaipaul
Which SSI hardware? Plz help :)
Guys,
I recently purchased a set of SSI's for my 79 3.0. Can someone please help me with which head to ssi gaskets I need? There appear to be a few different ones:
930-111-191-13-M30 and 930-111-191-13-M17
Also --- I assume these are the nuts that I should get to replace the old ones that hooked up the stock heat exchangers to the heads?
999-084-052-02-M260
Aaaaand… this is the muffler gasket? yes?
911-111-191-02-M17
Thanks!
Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 12-07-2014, 07:33 PM
Anyone?
Old 12-08-2014, 04:59 AM
sp_cs's Avatar
Your numbers look correct to me based on this UK site I used for reference when I fitted ssi's to my 3.4.
http://www.type911shop.co.uk/shop/category_71/Fittings-_-Heating.html?sessid=59c5FYVyMvAQNjL3SOUZWBUJifWDro XAayMAPCHytkurZAxyn6LJTL71hS6dTzyJ&shop_param=cid%3D%26
Shirish
1987 Carrera, Granite Green
Old 12-08-2014, 06:17 AM
Excellent! Thanks!
Regards,
Paul
Old 12-08-2014, 07:13 PM
I suggest using this link to confirm part numbers.
Porsche Original Parts Catalogue - Parts and Diagnostic Information - Porsche Service - Dr. Ing. h.c. F. Porsche AG
Sherwood
Old 12-08-2014, 08:29 PM
Y'know, in searching Pelican's offerings on gaskets for your application, I recall 25 years ago having the same question. Do you buy a gasket for the year engine that you have, or do you buy the pre-1974 gasket to match the SSIs? As I recall, I did the latter.
Brian
Old 12-09-2014, 06:40 AM
Guys,
Finally getting around to this --- Do these nuts 999-084-052-02-M260 replace the old 8mm socket type of nut 999-085-001-02? Looks like I have the socket type on my SC right now.
Let me know what your thoughts are!
Regards,
Paul
Old 02-22-2015, 12:43 PM
Not sure mechanical lock nuts are needed here. Nature has its way of locking these in place. YMMV.
At any rate, to stave off corrosion from future road muck, I suggest covering threads and fastener with anti-seize compound, before and after installing the nut. The socket-head nuts are factory and allow hex driver access through the HE, but not necessarily required if you can otherwise access them with the right wrench/tool.
Sherwood
BTW, the PParts description is a little confusing, "M8-13".
M8 is the threaded shank OD, usually followed by the thread pitch; exhaust studs and other 911 fasteners are commonly used M8-1.25. The "13" probably refers to the wrench size for the hex nut. However, 12mm wrench-size M8 nuts are sometimes recommended to allow better tool access in that area as are nuts made of copper in either size for increased corrosion resistance.
Old 02-22-2015, 12:54 PM
Sherwood
Ok - thanks for the response.
So in other words I can replace the existing hex "nuts" with normal locking nuts with locking nylon…. correct?
Thanks,
Paul
Old 02-22-2015, 01:43 PM
Thanks,
Paul
Don't think the nylon will last in this heated atmosphere. Nothing wrong with regular nuts torqued to spec. Probably okay, but I'm hesitant to use a nut that has a higher removal torque than necessary, especially when attempting to remove after 12 years in service. When you get a chance, observe the condition of HE nuts/studs in any under-car engine photo.
For example:
Sherwood
Old 02-22-2015, 02:02 PM
