964 G50 & 3.6 to SC
So I've done some searching and read a few conversion threads regarding the G50 into a sc. Many use the shortened bell housing to keep the engine in the correct location.
What I have is a complete 964 C2 and would like to do the G50 with the 3.6 into it. The car is a 1980 Sc and I'll be doing the coil over conversion. Has anyone done this conversion by removing enough material in the torsion housing and floor area to move it far enough forward?
I can do all the metal fab etc no problem but would like to see what others have run into.
Thanks for your help.
Old 12-12-2014, 10:16 PM
Search Brummie over on ImpactBumpers, he is part way through a similar project.
Old 12-12-2014, 11:11 PM
Not quite the same, but I am working on fitting a G60 six speed into a 1989 Carrera...glean what you will!
http://forums.pelicanparts.com/porsche-911-technical-forum/185692-fitting-6-speed-g50-89-carrera-new-post.html
Dennis
Old 12-13-2014, 06:54 AM
911 Bus: Since you're going coilover and are a competent fabricator, I think this job is relatively easy. I'm presently doing this by cutting away the area of the torsion tube between the two trailing arm mounts than fab'g cap plates (to the now open tube ends) that extend forward to the kick panel and upward to the jump seat bottoms. This is similar to how the factory did it on the later Carreras but my plates contact about twice as much area as the factory did. I'd consider adding plates to the seat bottoms where your tie plates will contact so to distribute the loading on thicker material across a broader area. I'll try to add pics later but hopefully you get the idea......
Marc
Old 12-13-2014, 07:13 AM
Thanks for the info everyone.
Metalracer, if you have some photos of your conversion that would be a big help.
Thanks!
Old 12-13-2014, 08:04 AM
Here you go. Keep in mind my plates are a little longer since I'm also converting the car to run 930 arms.
Old 12-13-2014, 09:55 AM
Thanks for the pic! Do you have a build thread? I'd love to see more.
Old 12-13-2014, 01:12 PM
gearhead
Cool projects.
Old 12-13-2014, 01:55 PM
ALEX P
ALEX P's Avatar
I was toying with the idea recently - You may find some useful info here:
915 to G50 conversion on '85 911 - What's needed guide‏
I chickened out at the cost!!
Old 12-14-2014, 01:29 AM
porsher
aston@ultrasw.c's Avatar
I installed a 95 3.6 with an 89 G50 shortened by Patrick Motorsports
...into an 86 Carrera.
In my experience the shortened G50 was not short enough and l had to cut away the outer torsion tube. Yeah it's ugly
In addition I let the engine move 1/2" rearward and modified the engine carrier instead of simply bending the engine cross member as others have done.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 12-14-2014, 11:03 AM
Goldmember's Avatar
I have a 1980 SC with a 964 floor welded in... To run an unmodified G50 on my 3.8RS Varioram build.
Max
1980 911 SC
1988 944 Turbo
...dreamin' big...
Old 12-14-2014, 07:54 PM
