Gene Smith's Avatar
Tail light assembly rear plate gasket
I needed to remove the plate on the back of my '69 911 taillight assembly to chase down an open circuit. Does anyone know a good way to reseal the plate? The existing gasket is destroyed. Is there a source for a new plate gasket? This is NOT the lens gasket.
Thanks.
Old 12-29-2014, 03:37 AM
When I took mine apart, I could see that the PO used Silicone sealant, spread thick. The were dry, so I decided to do the same. Only I used black silicone, whereas the PO used blue stuff that stood out like a sore thumb.
For added security, I ran another bead of silicone over the gap after putting them back together.
Old 12-29-2014, 08:02 AM
wrxnofx's Avatar
I think I've seen people use plumbers putty in the past.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 12-29-2014, 08:34 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Plumbers Putty
'85 Carrera Targa
PCA/POC
Old 12-29-2014, 09:14 AM
Gene Smith's Avatar
Plumber's putty won't make a mess- I think it is fine for my garage queen.
It is easy to remove if a future owner wants to "Split the ATOM".
Thanks!
Old 12-29-2014, 10:57 AM
Classic's Avatar
I went to a rubber supply place, and purchased some "U" profile.
Cut to fit, and super glued the ends together......worked well.
Classic 1969 911T
Old 12-29-2014, 11:18 AM
