Senior Member
Superman's Avatar
Brake MC
I don't hear much about brake master cylinders going bad on SCs, and I especially have not heard about vacuum boosters getting destroyed by leaking MCs. On the other hand, this may be a problem plaguing us without our knowledge. I imagine that vacuum booster units for our cars are spendy. I am therefore considering a new MC even though I don't know whether mine is bad or not.
Comments please.
Mocha 1978 911SC. "Coco"
Old 10-15-2002, 01:23 PM
Bill Verburg's Avatar
If it ain't broke why fixit?
Bill Verburg
Old 10-15-2002, 02:44 PM
Senior Member
Superman's Avatar
Well that's my point. It may be broke, and no one knows it. Yet.
I have seen quite a few corroded brake boosters. If our master cylinders are leaking past the seals, then that brake fluid is collecting in the bottoms of our brake boosters. Over time, this makes the brake booster into junk. I just checked it out. A booster is just over $300. A brake master cylinder is under $100.
Anyway, I was just wondering if anyone has ever had a booster go bad, and had to replace it. Anyone?
Old 10-15-2002, 02:59 PM
Early_S_Man's Avatar
Porsche Crest
If you do not yet have a problem with a rapid drop in the brake fluid level for one circuit, then you don't have damage to seals and cups from corrosion and pitting of the master cylinder cast iron bore ... so, the master cylinder would be a good candidate to rebuild at a significant savings over a new unit! Rebuilding the master cylinder and calipers every five years or so is one way to assure a troublefree braking system. The use of liberal amounts of Dow Corning 4, 111, or 112 on the cups and seals when replacing those parts ... assures maximum lifetime for those rubber parts!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-15-2002, 04:35 PM
Senior Member
Superman's Avatar
Wisdom. I know it when I see it.
Old 10-15-2002, 04:56 PM
Senior Member
Jdub's Avatar
Good thread Super. My '69 and '70 Mercedes coupe/sedan both experienced booster meltdown. You can rebuild these units (they are HUGE) or pay the $675.00 to replace them. One was so bad the only recourse was to get a new one.
The core I got for the old one was over $150.00!! That tells you something about their worth.
In all events, is there a rebuild kit for our Porsche MCs?
John
'78 Targa in Minerva Blue
Old 10-16-2002, 07:49 AM
Porsche Crest
John,
Raybestos still lists kit MK670 for SC/Carrera master cylinders w/ booster:
http://www.raybestos.com/catalog/parts.cgi?make=540&make_name=PORSCHE&model=120&model_name=911SC%20incl.%20Carrera&fromyear=1983
In my experience, all Raybestos kits for VW, Porsche, BMW or Mercedes contain a genuine Ate kit still in its' original blue box!
Warren Hall, Jr.
Old 10-16-2002, 11:48 AM
Senior Member
Superman's Avatar
Oooo. That's more good information. No wonder I like you guys.
Old 10-16-2002, 02:28 PM
