-   -   Dropping a 3.2, to do list? (http://forums.pelicanparts.com/porsche-911-technical-forum/843977-dropping-3-2-do-list.html)
gliding_serpent 12-24-2014 02:05 PM
Hi guys. My 84 is having it's 3.2 dropped this winter. Thoughts on things to do while it is out? Here is my plan so far:
- extensive detailing (including intake plenums, fan shroud, fan).
- SSI and M&K 2:1 install
- new fuel lines (trying to get in touch with Len for these)
- cut airbox to cup style (PO drilled)
- Heat backdate
- new cam oil lines
- valve adjustmet
- Reroute spark plug wires over fan (not S style)
- clean engine bay
- repaint engine surround tin
- new sound pad
- extensive reseal
Any other thoughts? Would like to do new vacuum lines (is there a good source of all the ones I would need?)
Jcslocum 12-24-2014 02:09 PM
Do vacuum lines and have the injectors cleaned.
Reseal triangle of death.
Adjust valves
zippy_gg 12-24-2014 04:34 PM
Inspect clutch and replace parts as needed.
Inspect and resurface or replace flywheel as needed.
Inspect clutch release fork for cracks and replace if needed
Upgrade the CHT sensor if the original is still there
Replace soft rear brake lines.
Inspect starter and alternator.
Replace intake manifold gaskets and torque bolts. Air leaks there will lean out the air/fuel mixture and may cause damage to the engine and will fail smog in CA. Easy and inexpensive fix/maintenance!;)
Jim Smolka 12-24-2014 05:58 PM
Another item to consider is to re-anodize all the fasteners and other small metal pieces so they have that new gold finish. Sometimes, the Worth clamps used in various places on the engine can be re-plated (anodized) as well
http://forums.pelicanparts.com/uploa...1419472703.jpg
Jim Smolka 12-24-2014 06:04 PM
Also, inspect the engine bay rubber seals that seals the engine sheet metal to the body of the car. Replace as needed. If done like it was at the factory, the new seal has a top part and bottom part. The top part goes onto top of the sheet metal. The bottom part goes on the underneath the engine bay sheet metal.
gliding_serpent 12-25-2014 05:15 AM
Thanks for all the info so far!
Jim Smolka 12-25-2014 05:41 AM
The oil pressure switch on the back of the motor
Jim Smolka 12-25-2014 05:42 AM
FYI, in the tech article section, there is information regarding the replacement of the clutch assembly.
midnight911 12-25-2014 09:28 PM
crank shaft seals front and rear,
plugs, rotors, caps,
rear suspension arm bushings, AND obligatorily
a pic of you in the engine compartment with a beer
BER 12-26-2014 01:48 PM
Just had my 3.2 out. In addition to your list (BTW - it's a good list), may want to check clutch/flywheel, clean injectors, replace o-ring seals on engine oil cooler and check the engine support/mounting bracket for cracks on the ends.
Have fun. :)
BER
Mark's 86 12-26-2014 07:57 PM
I replaced the speed/reference sensors when I had my engine out. The wiring on the originals literally came apart in my hands during their removal. heat, oil leaks, and age make them pretty brittle. Replace them and they should be good for another 30 years.
whiz05403 12-26-2014 09:05 PM
Awe. F it. Just do a top end while ur in there!!
gliding_serpent 12-26-2014 09:24 PM
At this rate I will just replace the entire car. ;-)
Ronnie's.930 12-26-2014 09:54 PM
GS, I recommend you add one of these to your "to do" list! :D
http://cdn2.bigcommerce.com/server31...0.1280.jpg?c=2
gliding_serpent 12-26-2014 10:18 PM
only one???
timmy2 12-26-2014 11:00 PM
Inspect all engine harness and injector wiring for brittle areas that may have developed cracks and repair or replace.
michael lang 12-27-2014 03:14 AM
Clean, clean, clean and clean some more. Just when you think it's clean, clean some more. That job never seems to end. I'm not doing this but I considered splitting the case just to make cleaning that much easier.
cabmandone 12-27-2014 05:35 AM
My suggestion would be when you're done with yours, come to Ohio and help me with mine.
spence88mph 12-27-2014 05:45 AM
+1 X1000
Also, torque your intake manifolds...
ned903 12-27-2014 06:04 AM
Back to your list, how are you planning on re-routing your spark plug wires. I am trying to get the wires back to their original position on the fan shroud of my '87, but have not found a really good solution.
