911 sc
After a long ordeal I have finally finished replacing chain tensioners in my 80 sc.
It is buttoned up and ready to fill with oil and turn the motor over after a long rest. I think I need to disconnect the coil from the distributor to pump up the oil pressure before trying to actually run the engine. How do I know if everything inside has been coated with fresh oil before actually trying to start the engine? I sure do not want to cook something inside the engine. Thanks
Old 12-27-2014, 07:14 AM
Project Addicted
When you see oil pressure on the guage and or the low oil,pressure light goes out.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 12-27-2014, 07:27 AM
ROW '78 911 Targa
timmy2's Avatar
Pull the fuel pump relay and crank it over until you see the oil pressure light go out and pressure on the gauge.
Old 12-27-2014, 10:28 AM
