-   -   Should engine & trans numbers match? (http://forums.pelicanparts.com/porsche-911-technical-forum/844314-should-engine-trans-numbers-match.html)
gwinnch 12-28-2014 09:57 AM
Numbers for my '85 Targa:
Engine *64F03571*
Trans 915/73 74F 03521
Should I be concerned that one's a "7" and the other's a "2"?
Thanks in advance and Season's Greetings to all!
Bill
Bob Kontak 12-28-2014 11:54 AM
I bet that a few of the 1985 US engine types were fitted with the 915.72 transmissions with an oil cooler. The serial # range for those are 73F 00001-10,000. I say "I bet" but not sure if the Euro/ROW type 72 could be imported.
The 74F XXXXX transmissions were made up of type 68 and 73. Type 68 appears to be a spill over from 1984 inventory or a mid model year change to the type 73.
http://forums.pelicanparts.com/uploa...1419796435.jpg
See PDF page 522-ish for the engine and trans types.
http://www.porsche.com/all/media/pdf/originalparts/en/E_911_86_KATALOG.pdf
Hil911 12-28-2014 02:07 PM
Did Bob's awesome response answer your question, or were you asking whether they should be the same number?
I don't think so. It's pure chance when they drew an engine and gearbox from the pools with the same number.
Maybe with just in time ordering they keep a smaller stock and it is more likely to happen?
Bob Kontak 12-28-2014 02:38 PM
Originally Posted by Hil911 (Post 8413980)
...or were you asking whether they should be the same number?..........I don't think so. It's pure chance when they drew an engine and gearbox from the pools with the same number.
Thank you. I got so wrapped up in the numbers I did not directly answer Bill's question.
Awesome? Thanks. Truth be told, I am frittering away time when I should be finishing up this old Jetta suspension. The more elaborate the answer, the less I have to lay on my back.
gwinnch 12-28-2014 04:27 PM
Just was wondering if they should be the same or just close...thanks to both of you for the info.
djpateman 12-28-2014 04:33 PM
No, we would not expect them to match; that is not how things are done at the factory. Engines and transmissions are grabbed at random provided they are the correct type for the order being processed. I'd say that there has to be an error in that chart above; types 68 and 73 cannot have the same serial range.
patz 12-28-2014 05:51 PM
"numbers matching" is an American thing. The Germans use books and records. But buying a COA doesn't mean it's always accurate.
Germans ain't what they used to be.
Hil911 12-28-2014 06:18 PM
Hey Bob - you know what? I'm supposed to be painting a bedroom at this very moment!
Hil
JJ 911SC 12-28-2014 06:25 PM
Hil
Color on wall is overrated!!!
My "Honey Do" list is about 4 pages long... Not going to happen until I retired :D:):D
