brock911's Avatar
Suggestions for repairing pinholes in muffler?
Greetings from Canada, all the best for the holidays and health in 2015.
I'm preparing my muffler for re-paint, after a media blast I noticed 3 very small holes approximately 1/8" diameter.
Looking for some suggestions to repair these pinholes, epoxy, muffler cement, brazing of some type or welding?
Maybe you have experienced this issue or can recommend a fix?
As all ways your help is appreciated.
Regards,
Mike
Old 12-24-2014, 06:42 AM
non-whiner
mreid's Avatar
Pinholes are usually a sign that it is rotting from the inside out. That means that the metal is very thin and will be almost impossible to repair. Your best and safest approach is to replace it. If that's not possible, brazing may be your only option, but will not last long as other pinholes will develop. Welding will blow through and expose all of your woes.
"Too much is just enough."
Old 12-24-2014, 06:50 AM
Oh Haha's Avatar
Which of your cars has the holy muffler? If it is the 912 a used one would be MY choice for fixing the issue.
Pacific Blue
Wayne
Old 12-24-2014, 06:54 AM
brock911's Avatar
Thanks for your input Mark, I realize it may be futile but I'm hoping because the holes are small enough it may be salvageable?
Regards,
Mike
Old 12-24-2014, 06:55 AM
Cattler's Avatar
Porsche Crest
+1 on replacing. I wouldn't think repair would be cost effective.
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
brock911's Avatar
Hello Wayne, it's the 66 911.
Old 12-24-2014, 06:56 AM
tharbert's Avatar
Short term: How about a short pancake head screw and some epoxy? You'll never be able to weld it.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 12-24-2014, 07:00 AM
non-whiner
mreid's Avatar
Sorry, Mike! It gets too hot for epoxy to last very long. If you can braze it yourself, that is really the only cost effective temporary solution.
Old 12-24-2014, 07:16 AM
jmpowers's Avatar
I'd guess that it once you put enough heat to braze or weld it you will create a bigger hole than you started. Looking at JB Welds site this product might work?
Good luck
-John
1987 Targa -Diamond Blue Metallic
Old 12-24-2014, 07:40 AM
Ahhhh, the ever lurking JB Weld myth raises its ugly head.......
The Cap'n
Old 12-24-2014, 08:10 AM
High temp silicone with a metal screw?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-24-2014, 08:21 AM
Diss Member
Quicksilver's Avatar
Braze it and just watch it.
That also gives you the luxury to keep an eye out for another muffler to show up at a good price.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-24-2014, 08:52 AM
brock911's Avatar
Thanks for all the input, upon closer inspection it appears there is one hole.
The muffler has what looks like an outer wall of metal as well as an inner wall?
Only one small hole looks like it is right through and the metal all around this area appears quite solid to a good poke with a sharp awl, is this just wishful thinking?
There doesn't look like any rust in the area at all. I will post a couple of images later when I get home, not that anyone will be on their computers on Christmas eve.
Once again thanks for the help.
Mike
Old 12-24-2014, 09:26 AM
Id just weld it up. Sounds like a pretty small area that water collected. chase the holes around till they are gone grind it smooth
Old 12-24-2014, 09:45 AM
+1. I would add a metal patch with multiple holes for brazing. That should add some structural strength and extend its life a little. Gently bead blast for paint prep, but don't spend a bunch on making it look presentable.
Sherwood
Old 12-24-2014, 11:30 AM
Post #2 mreid nailed it. I had same problem with 70 muffler. The muffler is indeed rotting from the inside. I absolutely believe replacement is the best option. If it is the original 66 muffler just think of how much service you got out of it.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 12-24-2014, 03:01 PM
brock911's Avatar
One more question, I'm planning to try brazing the pin hole for repair because I feel the area around the hole is solid enough to withstand the heat, this could simply be wishful thinking but I believe worth a try.
However, before I attempt this I was wondering if a rivet would work?
Thank you for your opinions,
Regards,
Mike
Old 12-28-2014, 07:08 PM
patz's Avatar
50 years? Probably due for retirement.
Old 12-28-2014, 07:25 PM
Brass doesn't like vibration, which is pretty substantial in that area, and it requires a squeeky clean base in order to adhere well. Keep that in mind.
The Cap'n
Old 12-28-2014, 08:07 PM
Regards,
Mike
Pop rivets to plug a pin hole? Try it.
Old 12-28-2014, 09:52 PM
