I need to replace all 4 tires on my '85 911. I'm not planning on racing, but I do enjoy the responsiveness of a high performance tire for weekend drives on winding roads. I'd like to stay in the sub-$150 (per tire) price range. The tire shop recommended the Dunlop SP8000 (205/55/16 in the front @ $95 ea.; 245/45/16 in rear @ $140 ea.). I'd appreciate any advice you may have on the quality of Dunlops and the price.
Thanks, F.
'85 911 Coupe Last edited by Frenchy; 10-14-2002 at 03:57 PM.. |
Frenchy-
It would entirely depend on what your plans are for your car.
Chris Bunker 78 SC |
Super Moderator
Dunlops are a decent street tire, but certainly not the best. Bridgestone S03's happen to be my fav..
I have only heard good things about the S-03's. RoninLB from the board has them. I know he got quit a bit of mileage out of them as well
I had the SP8000 on my car when I bought it. I wasn't very impressed by them (track impressions), however, in all fairness they were quite old and had many a heat cycle put to them.
If Drivers Ed/AutoX is not in the plan, then I would say that for most people doing normal everyday driving, its hard to go wrong with just about ANY of the current crop of high performance tires out there. It becomes a question of price and appearance.
If you have 16" wheels - tirerack.com probably still has the Yoko AVS Intermediates for about $ 60 each. I am running a set now and drove in the rain yesterday for about a hundred miles - I have been pleased with these tires so far - wet and dry.
SO3's are supposed to be awesome but at double to triple the cost of the Yoko's.
Randy '87 911 Targa '17 Macan GTS |
Senior Member
Don't mount 245s onto 7" wheels. If you have wider wheels, fine. but if your wheels are stock 7" fuchs, then 225 is as wide as you want to go.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Is it okay to mount a wider and lower profile tire on a 7x16 inch wheel? I was thinking of something in a 40 series tire. Would that be okay?
Michael |
I have the SP8000 on my SC. They are a fine tire for the street. A very good value tire.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Michael,
Remember, the object of the game is to keep the overall diameter of the tire/wheel the same as stock. So, if you go with a larger wheel, you'll need a lower profile tire to retain the correct outer diameter. If you haphazardly go with a lower profile tire on a 16" wheel...for one, it'll look bad (too small for wheel well), your speedo will be way off and your alignment will be wrong. The only up-side is that you would be essentially changing the gear ratio of your car and would enjoy quicker acceleration out of the hole, but at the cost of a lower top end. Bottom line....don't do it.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
PRO Motorsports
Do you see very much rain?
If you see a fair amount of rain, or you are concerned with rain performance, you really should get Bridgestone SO-2's (if they still have them) or SO-3's. They are amazing in dry and wet. If you never see rain, or never drive in the rain, the Dunlop SP8000's are a very good dry tire. The Yokohama AVS Intermediates are pretty awesome in the dry, but aren't up to snuff in the wet compared to the others. The Kumho Ecsta's are a very good bang for the buck as well. The ride is great, not too noisy, pretty grippy, but they are lead bricks! Heaviest tire I've ever felt! Probably not an issue for a street car though. They're cheap! The SO-2's wear out pretty quickly, and get a bit noisy mid-life. Not sure how important treadlife is to you.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Automotive Writer/DP
Bridgestone SO3, Yokohama AO32R, or BF Goodrich T/A KD would get my vote. AVS Intermediates are second tier now and Dunlops do not offer the grip the others provide.
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
A 225 50 16 will ultimately handle better on a 16x7 than a 245 45 16 will assuming the same tire make and model. because the wheel is too small for the tire the contact patch won't be optimal and the sidewall while shorter will actually be more bulbous and so flex more.
If you want more rubber on the ground you'll need to get larger wheels or optimize the tire for the rim. For instance a 225 50 16 Bridgestone RE730 actually has a slightly skinnier tread profile that the same size Bridgestone S-03, I think. So check different tires to see if one lists more tread width, but across brands the measurement might vary.
Hello,
Thanks for the great information. Yes, in the back of my mind I knew it was not the right thing for all those reasons but I guess I really needed someone to tell me. As for aftermarket is there a recommended wheel company that will offer something for the early 911's offset? I am looking for something with a nice fat chrome lip. What would the max in width my 911 can hold in a 17 wheel. I do want to go with a 40 series tire. Yes, for looks mostly. I cant lie but I do intend to do tack days with the 911 also. The 40 series tires would definitely be an upgrade. Calspeed |
The Fikse F5 wheel is also a very strong, lite-weight wheel that will retain the 5 poke Fuch "look" both have the "chrome" look to the lips. AS to your intitial question, I am on my second set of AVS tires and like them both on the track and for all-year street driving. But as someone posted, the AVS has been surposed and is probably a second tier tire at this point. S03's sem to be the hot ticket and will be my next tire.
How come nobody ever mentions Pirellis? I thought these were great tires - I was looking at getting some P-Zeros for my p-car.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
I was considering the S03's, and if price was not an issue would have gone with them. Decided instead on the AVS Intermediates and have no regrets. Great tire for the price!
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Thanks for the info PBS911. I have also considered the Fikse Wheels and now I am looking at Kinesis. More later... Thanks
Calspeed,
I should point out that the 7.5 and 9 " width wheels fit very nice with almost no camber. Recently I went with 1.25 and 2.0 camber settings, front to rear. With these settings It looks like I could have easily gone with 8 and 9.5" wheels. So if you plan on running extra camber you can may be able to add a little more width if you like.
