Injectors
Hi, I’m about to replace several injectors o rings after discovering a vacum leak. I’m thinking about cleaning the injectors while they are out. How do you guys clean them or should I have them professionally cleaned? Thanks dave
1988 Carrera
Send them all to Mr. Injector. He will clean them and test them and send you a report. Abouth $125.00
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Yup, several services that clean and flow-test them. I used InjectorRX in Houston; they were a little cheaper ($108 plus shipping) and gave me a very nice report.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Guest
Posts: n/a
I used Dr. Injector. They did nice work. Had to replace one because of a non-repairable leak. It was a little tough finding a new one at a reasonable price (Dr. Injector did not cary the right one).
Thanks guys for the advise, I'm going to remove them and send them out for evaluation / cleaning dave
What kind of injectors do you have? I don't think that Mr. Injector will clean/refurbish the CIS type injectors, or at least they didn't last time I looked.
I sent mine to Witch Hunter
https://witchhunter.com
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Yes I haveCIS injectors....
The Dude abides...
Dave,
I sent my injectors to Mr. Injector (Bill Johnson) in Dalton Gardens Idaho. They give directions on how to pack, wrap and seal the injectors in zip-top bags for shipping to them. Bill did a great job on my injecotrs - ultrasonic cleaned, tested for flowrate and spray pattern, oiled and painted for $17.50/ea. Report provided upon return showing performance before and after service for each injector. Quick turnaround as well. I was very happy. Can’t recommend Mr. Injector enough.
Steve '03 Carrera 4S |
That's what I needed to hear- I'm going to send them to Mr Injector. Thanks for the recommendation!
+1 Mr. Injector - outstanding service
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C |
The Dude abides...
Happy to help. I find this forum priceless in so many ways, getting solid recommendations prior to pulling the trigger on a purchase/service is just one of them. One other item I forgot to mention, which should be obvious, is Bill also replaces all of the ‘wear parts’ O-rings, etc. as part of the service.
Be sure to post your experience once you get them back. By the way, I was able to dig out some pics of my injectors, before and after servicing. ![]() ![]() Good luck!
The 9 Store
Ive sent about 200 injectors to Mr Injector. Happy every time. He replaces all the needed seals and screens and flow tests before and after. Makes them look like new.
All used parts sold as is. |
Injectors
Just got off the phone with Mr Injector, he does do CIS injectors As noted. He did say he does not do the CIS that injects directly into the cylinders
, but if the injectors mount into the intake manifold he does them. Hope this clears up any misunderstanding. Dave |
