thrown_hammer's Avatar
Arrow 2.7 CIS guys please chime in...
I think I have solved my sputtering problem. What I need to know is this... The car pulls strong from 3000 to 5000ish RPM. From there to redline is doesn't seem as urgent but still pulls to redline with no hesitation in 1st and 2nd gear.(3rd is a bit risky on the way to and from work)
What RPM does the HP/Tourqe peak? Is this the typical power curve for a stock 2.7 CIS car?
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 10-16-2002, 07:52 AM
I hope this helps:
http://www.middleyear911.com/techspecs.html
It's not important to be the best, just do your best.
Old 10-16-2002, 08:41 AM
So with this data would that explain that the rush of acceleration drops off a bit after 5000 RPM since the torque peaks at 4000RPM?
1975 2.7 911S USA 49-state 8.5:1 2687 cc, 165HP @ 5800 RPM, 167 lb/ft @ 4000 RPM
1975 911S (sold)
Old 10-16-2002, 08:54 AM
Assuming that this data is accurate, yes. Remember, torque gets you going from a start, but HP is what makes you faster after you're going. Of course, timing will affect both of these (timing that's too advanced will decrease torque but increase HP). There is really no need to wind your car to redline to achieve peak HP since you've already maxed out these around 5800 RPM.
Old 10-16-2002, 11:12 AM
I am going to assume your car is a 1977 targa. Does your car drop off on acceleration after 5000RPM? Mine still acellerates but not with the urgency that it did from 3000-5000RPM.
1975 911S (sold)
Old 10-16-2002, 11:37 AM
power drop
I am pleased to tell you that my 1977 cis, 2.7 L continues to pull steady into the redline/rev limiter range. I have 74,00 miles on it. The timing is at 3 deg. atdc, the dwell angle 41 degrees with points set accordingly (I forget now).The cis is on the rich side. My problem is in the lower gears getting up to max too quickly and not floating the valves. As you might guess, I love my car. I have also taken pains to be sure that I do not have any vacuum leaks in the system. I am presently thinking about purchasing new injectors just to be sure that she stays right.
Old 10-20-2002, 05:03 AM
Buy them, sell them
Adam's Avatar
I had similar problems until I had new injectors fitted to my '76.
It pulls very cleanly up to the redline, but I think after 6k rpm, it's making more noise than power.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 10-20-2002, 06:34 AM
marcesq's Avatar
Thrown:
The 2.7 engine should spool up from 4k to redline until it hits the rev limiter.
What heat exchangers do you have?? and what are your timing and point settings??
How old are the spark plugs, wires, distrib cap and rotor??
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 10-20-2002, 09:34 AM
