they look awesome!
1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html |
I cannot believe how nice and "modern" the bbs wheels look. Used to only seeing it in the familiar gold, the gray makes them look quite nice.
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
Wow those look amazing. What are your offsets in the rear?
The rear wheels use a 5" outer halve along with a 6" inner halve.
The backspacing is about 5-9/16" (tad over 5.5").
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Came back just to see these wheels, they look too good.
I need to learn how to build wheels, brand new 3 piece wheels are outrageously priced nowadays. |
Relatively simple to do....regardless what a wheel manufacturer may tell you.
Always use new O-rings between the wheel halves. Make sure everything is clean. Bolt them up, and torque to ~13 ft-lbs. I then run a bead of silicon sealant around the entire perimeter where the O-ring is as a backup against air leaks. Sometimes good 2nd hand wheel halves are available. If not, new ones are not inexpensive. I spent $150-200 per halve.
Nice I appreciate that, I'll do some hunting around and hopefully you see me posting about it soon!
SWISS in cali
What size are your barrels? inner and outer? thanks!
05 Audi S4 Avant 65 VW Camper bus 03 Audi TT Roadster 04 Cayenne S 98 Audi A4 Avant |
Excellent!
who do you guys recommend to polish the chrome 3 pc rims from E50 bbs wheels? does all reed do the rims only? i will reassemble myself.
thanks . frank |
