Epsilon Rims
Hello,
I found a set of Epsilon 16"x8" and 16"x9". The owner said that they fit on Porsche 911 from 1978 to 1985. This is the only info that I have and the wheels are not that close to me. So I was hoping to get some info from you guys. Does the 8" rims fits in the front without rubbing and without any mods? I want to install them to a 1987 carrera. Also what is a fair price for them.
Thank you.
Old 01-15-2015, 02:01 PM
Bill Verburg's Avatar
Originally Posted by x19m3 View Post
Hello,
Thank you.
All the Epsilon wheels I've seen have the o/s data on the back, you need that to know fitment.
As extra insurance get the edge to edge and backspace measures
Bill Verburg
Old 01-15-2015, 02:19 PM
Ok, I will ask for that data. But are the 8" fit on the front?
Old 01-15-2015, 02:22 PM
They can but it depends on the o/s and tire used, sometimes other factors too but the biggies are the ET and tire
Bill Verburg
Old 01-15-2015, 02:31 PM
What do you think is a fair price for them? $500?
Old 01-15-2015, 02:33 PM
The owner state that they fit on the 1978 to 1985 . Is the SC suspension same as the 87 -89 G50?
Old 01-15-2015, 02:38 PM
Rescuer of old cars
Arne2's Avatar
Yes, 78 through pre-964 cars are all the same for wheels.
8" are frequently tight fit on the front. But I question whether they are really 8s and 9s. Many people don't know how to measure wheels. If they are measuring the outside lip to outside lip, then they are really 7s and 8s, as the wheel width should be measured at the bead seat, not the lip.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-15-2015, 03:32 PM
I have the identical set and would bet they are in fact 7's and 8's. They are Epsilon SW's and they will fit up to the '89 911 (early offset / pre-ABS) cars. The 8's will fit on the front of a non-turbo car...tight though but that means you would need to source a pair of 9" for the rears and I can't remember seeing a 9" one in ages...or ever.
You can also run a square set (8" front and rear) but stagger your tire size but I personally don't see the point in that.
The backspacing on both the 7" and 8" should be 5".
Old 01-15-2015, 06:58 PM
