How to remove the vacuum line on 1987 3.2 carrera W/out unmounting the engine
Hi:
My 78 3.2 carrera engine suffers from the idle hunting problem when the engine was warm. I check the ICV and that's not the reason. So its down to the vacuum line and I saw cracked rubber on the left hand side hose of the vacuum line. It seems to be a huge project to get to the vacuum line and need to unmount the engine to do so. Is that any chance I can remove the engine heater blower and unscrew the vacuum pipe easily? Regards |
I don't think you have to drop the engine to do vacuum lines. I have been considering doing the vacuum lines on my car and figure I'd just remove all the small things that come off easily and deal with the rest.
I think mine had the same problem as well. |
which vac line did you see that was cracked? I thought you meant that one (to the rear tunnel) - There are quite a few ya know, but this one is the most fun.
| All times are GMT -8. The time now is 04:05 AM. |
