How to remove the vacuum line on 1987 3.2 carrera W/out unmounting the engine
Hi:
My 78 3.2 carrera engine suffers from the idle hunting problem when the engine was warm. I check the ICV and that's not the reason. So its down to the vacuum line and I saw cracked rubber on the left hand side hose of the vacuum line.
It seems to be a huge project to get to the vacuum line and need to unmount the engine to do so.
Is that any chance I can remove the engine heater blower and unscrew the vacuum pipe easily?
Regards
Old 01-18-2015, 06:45 AM
Brew Master
cabmandone's Avatar
I don't think you have to drop the engine to do vacuum lines. I have been considering doing the vacuum lines on my car and figure I'd just remove all the small things that come off easily and deal with the rest.
Old 01-18-2015, 06:50 AM
steely's Avatar
Do you mean this big one?
vacuum leak you probably didn't ever think of
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-18-2015, 09:08 AM
Originally Posted by steely View Post
Wooo, that's a nice hint. I'll check mine next weekend.
I think mine had the same problem as well.
Old 01-18-2015, 01:35 PM
steely's Avatar
which vac line did you see that was cracked? I thought you meant that one (to the rear tunnel) - There are quite a few ya know, but this one is the most fun.
Dan
Venetian Blue
Old 01-18-2015, 01:48 PM
