quick questions
What is the compression ratio for a 2.4T and can mid grade gas be used, 89 octane.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
As I recall, 2.4 S is 8.5 CR, E is 8.0, T is 7.5 CR.
Anything will run in any of the CRs |
If its a stock mfi car and you don't run a lot of advance, then 87 works just fine.
72 911 Although it is done at the moment, it will never be finished. |
Now that was quick. Thanks.
Interesting, but here in Montana (and elsewhere too) I can find alcohol free gasoline but it's 91 octane. Am I wasting my money? By avoiding the water-gathering nature of ethanol, I don't think so. Should I adjust my mixture to compensate? (I have a '75 911 Carrera engine.)
Questions beget more questions!!! Thanks, Tom |
Tom:
The risk of ethanol to our cars is from corrosion of the steel and rubber parts wetted by the fuel. The metal corrodes and the original rubber gaskets are not compatible with ethanol. The octane is a secondary concern. It does not hurt to have too much octane.
