Suspect such an animal doesn't exist.... From strictly an engineering viewpoint there would be little reason. Pre-amp outputs are voltage level, Maximum of ~3V typical. Speaker output are current level to drive the speaker's low impedance voice coil. Without a DC-DC voltage converter 12V, battery voltage, 24V (+/- 12V) for output "H" bridge circuit. Speaker output levels will likely be highly distorted driving a high resistance amp input rather than a voice coil. |
Ok, going for a short drive, sitting in the garage anyway.
rwest, wwest, and all, Sound like wirth a try. Worst case is a day of labor. Thanks all. Quote:
This an another amp I had comes with low level input (RCA) and high level input (speaker wires). On high level input, I don't know enough if the amp takes it as it is and amplify it, or take it in, then reduce it, then amp it up or if it's only a myth.
Sounds like you're making the best decision for you. I respect that. Boss is entry level equipment in the car audio world. That's why you can find it for such good prices. Please keep us posted on how your system turns out. |
I don't think the latter would be a wise move. |
wwest,
no, west. What you are saying is taking the speaker wires and connect them to RCA jacks then plug them into the amp. I know this will work, but might not be good. What I meant was there are RCA inputs on the amp (low level input), and there are also wire connecter inputs on the amp. (high level input), to connect speaker wires to it. What I was saying is that I am not sure how this option (connect speaker wires directly to the high input of the amp) works internally. |
I have owned a car audio shop in NY for 30yrs. SoundFX. The boss line of equiupment in plane english is total JUNK. Save some extra money and you can buy a good head unit for 125.00 or so. Stay with a pioneer, alpine, or kenwood.
Hi level inputs were designed for amplifying a stock headunit with no RCA outputs. You can get decent results. The RCAs are the way to go. A standard headunit will put out about 2v. Were your better headunits put out 4v. The Boss is probably putting out about .5v and horrible quality signal also. https://www.facebook.com/pages/Sound-Fx/132546535630 |
Thanks JBrrown,
With this comment, I won't want to waste my time. I guess same comment goes for those "XO, DP, ..."? They all looked the same so I assume they are the same manufacture. For the name brand, have you seen one with an SD card? Thanks. |
rnin,
Check out this Blaupunkt at Crutchfield: Blaupunkt Adelaide 130 Digital media receiver at Crutchfield.com They have others as well from many brands that are media only, no CD. |
Based on the very reasonable cost of head units, maybe sniff around and go all out and spend $125. If cost is very important, search your sofa for quarters and get the $75 unit. |
Thanks guys. Frys has a JVC, no SD card but there is a USB. I might go there tonight to see if I can listen to it.
Thanks again. |
this may work for you too -- it's an alpine M-bus (which your existing alpine head unit appears to use) adaptor that replaces the cd changer with a sd card and usb reader that lets the alpine play mp3s . . . Yatour M bus USB Car Adapter CD player mp3 interface cd changer CDM 9825RB, CDM 9823R TDM 9501R/RM Fit Alpine-in Audio from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Bob kontak,
yes, cost is important on this, because I don't value the car music as much as when I'm younger anymore. Rodek, I went to a local store to look at the boss and other off brands. Oh mine, just the look can turn you off. Sales guys laughed when they hear I am thinking of taking those to replace my Alpine. So I finally got a JVC with USB and all preamp outputs to keep the configuration the same as it is. guys, Honestly, I like the look of the older type head unit better. Most of the new head unit look bulky and flashy. Also, the older type is more user friendly. On all the modern head units, it is hard to get to any feature because there are so many features now and there are much less interface. It took me a lot of tries to get to where the balance and fader are. Thanks everyone for advices. Quote:
