Driver's License Owner
Clutch pedal stuck on shaft - need help
Diassassembling pedals. Was able to remove the roll pin but clutch pedal will still not come off shaft. Tried breaker-bar, fire/heat, kroil, air hammer, etc. Any advice?
Keep fighting, they are a nightmare!!!
Phew! Got it. Used a small sledge hammer to knock it in a bit further just to get some movement. Then air hammer got it moving out. Maybe the kroil had started working too. Worst part is the second guessing.
Member 911 Anonymous
Yeap, rust welded, it happened to me and I live is SoCal
Just got to knock it out. place anti seize when replacing. it will help for future work.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
