-   -   part numbers for 78-80 turbo rotors???? (http://forums.pelicanparts.com/porsche-911-technical-forum/84882-part-numbers-78-80-turbo-rotors.html)
dickster 10-21-2002 11:28 AM
i'm looking for the part numbers for the oe centre "hat" part of the three piece front rotors.
cheers in advance.
emcon5 10-21-2002 11:43 AM
http://forums.pelicanparts.com/uploads/partImage1.jpg
http://forums.pelicanparts.com/uploa...akenumbers.jpg
dickster 10-21-2002 12:24 PM
emcon5
appreciate that, but i'm looking for the part that bolts to the hub - i don't seem to see it there?? or is it the flange.....
that looks like the back plate on the left, the part i'm looking for would be to the right???
or am i totally confused :confused: :confused: :confused:
sorry, i'm putting turbo brakes on a '86 3.2 and all i know is i need the rotors and hats but not the spacers. looking at the diagram aint what i was expecting:(
help needed/appreciated;)
dean 10-21-2002 04:42 PM
I think you need what is called a hat. It mounts the floating rotor to the hub. I would not get the factory part due to the cost. There is a place in NJ USA that sells them at a very reasonable price. I am sure they would ship to the UK
Power Tech 973-586-3210
Ask for Mike
Good luck and have fun
89911 10-21-2002 05:27 PM
This place can sell you the hat. http://www.vehiclecraft.com/
I am doing the 930 rotor upgrade also. This company also has there own rotors and hats. You can find the orginal ones for these turbo's but most parts shops don't know much about the items numbers.
Bill Verburg 10-21-2002 08:08 PM
Tom, provided the #s that you need. Unfortunately they have been NLA for many years. In addition the factory hats only bolt to the original factory 930 hub which is different from the 911 part. Your best bet is to get an aftermarket hat that will mate the factory spec rotors and your 911 hubs. There are many sources for the hats. But to my knowledge Steve Weiner at Rennsport Systems is the only supplier of the correct rotors. The Brembo/AP rotors that Steve has are more expensive than the Coleman rotors that other vendors sell and are worth it
http://www.rennsportsystems.com/~por...0brakekita.jpg
dickster 10-22-2002 01:00 AM
i understood you can use the 78-80 rotor assem. and just discard the spacer - oh well.
i can get the rotors (oe) real cheap here (uk) so was gonna find out about hats as well but i needed part numbers.
calipers are being shipped to doug at vci today, guess i'll be buying a bunch from him now, can't wait to get them back though.......
thanks as always. ;)
89911 10-22-2002 05:31 AM
Apparently, If you buy the rotor/hat assembly from vci, it is a better deal then just the hats and rotors seperately. Check there website. You best deal may be to buy these first as a unit, and then OE rotors later. There rotor is a direct replacement for the 78-80 rotor. The cheapest I can find these US is $219/rotor compared to there price of $249. Have you thought of getting these frozen? For this price, it may be worth it!
dickster 10-22-2002 05:43 AM
89911
i can get oe rear rotors here for US$142!!! (i'm building on a budget here and need all the $'s saved i can get!)
i'm gonna get the rear calipers machined, front hats, all lines, hardware, and perhaps front 1/4" wheel spacers (extended studs??) and m/c from vci - vci may also need to mod the c/over lines on the rear calipers.
i'll use oe rotors and pads to start with to save $$$$.
doug there has been great and very patient with all my questions. ;)
hows your install going???
dean 10-22-2002 06:27 AM
I wanted to use the factory 79 930 rotors on my car. I talked to Steve W and asked him if his hats would fit the oe rotors. He said no. So I found Powertech in NJ and they said that there hat kit would fit the floating rotors. So that is the way I went.
The best price I found for the oe floating rotors was $250 each.
dickster 10-22-2002 06:39 AM
blown
apologies i missed your first post.
how much were the hats at powertech??
ouch, i'm glad i can save on the oe rotors, it'll make up for the shipping costs for the calipers!
89911 10-22-2002 08:45 AM
1 Attachment(s)
My calipers should be in soon. If you can get those prices, certainly do so. Those prices I quoted also are deep discount prices. At the dealer, those rotors are going for around $300:eek:
dickster 10-22-2002 09:18 AM
89911
nice, they 'kin huge aren't they? you gotta get those machined??
dean 10-22-2002 02:46 PM
Hey Dickster,
The hats cost me $200 plus the dogs and the bolts. They kind of nick you on the bolts so you can buy your own. I paid $300 for the hat kit.
dickster 10-23-2002 10:47 AM
dean,
thanks appreciated, i've emailed them to get info.....
964RS 10-23-2002 12:54 PM
Dickster
I used the VCI hats and the Porsche front discs - they fit perfectly. The downside is the floating set up is a little noisey at low speeds. If you don't need the floating set up and are prepared to pay a bit more than the original equipment is over here, I would go for a non-floating set up that Doug and others sell.
Hope this helps
dickster 10-23-2002 01:50 PM
steve,
thanks, i'll see what powertech come up with. but i really have been impressed with vci - i'll see how it goes with the machining etc.....
i'm not that bothered about the noise. keeping the cost down is priority though!
sorry for the ignorance but i have no idea what setup a 964rs has - what did you use??
ChrisBennet 10-23-2002 02:16 PM
I have the VCI floating rotor setup with S4/993 calipers in front and 930 calipers/rotors in the rear. I think I used PowerTech to machine the 930 rear calipers. PowerTech charged about half of what VCI wanted. I suspect that if PowerTech has a front hub solution for you, they might be cheaper than VCI on that as well.
If I was doing it again, I would find a solution that used factory non- floating rotors. When the Coleman rotors wore out I replaced them with Porsche ones. I got a good deal ($247ea) but that is quite a bit more than the non-floating rotors would cost.
I have to remove my track pads (Pagids) on the street because they are painfully loud - as in "causing actual pain" to bystanders. They aren't bad with street pads. I started swapping pads when I frightened a horse...
-Chris
dean 10-23-2002 02:45 PM
I like the noise the floating rotors make. Plus I like the racing technology. I would go the same route next time with a couple exceptions. I might go with Big Reds and I would source my own bolts for the dogs. All to save some bling (Thom I am trying like hell to keep up).
ChrisBennet 10-23-2002 06:00 PM
I was driving to lunch one day with a guy from work and he said car had never sounded worse - referring to the squeaks of the brakes and the clopping of the floating rotors. He had an aeronautical background so I told him my car was a bit like an SR-71 on the ground, the way the gas pours out of the wings.
Both machines work better at speed.
-Chris
