non-whiner
Critique my engine build
Input appreciated. I'm building a 3.0 (actually 3.2 SS). I have a solid 1978 3.0 bottom end, 98mm cylinders with 10.5:1 3.0 JE pistons, big port 3.0 heads converted to twin plug, DC80 cams with 104 lobe separation, and a dual plug distributor. I'm thinking 46 PMO carbs. If it helps, this is going in a 2000 pound 904. Thoughts?
"Too much is just enough." |
Diss Member
All sounds like good stuff so far.
What are you looking at for rods? You have components that will really breath at the top end so you want to be sure that the rods and rod bolts are in their "comfort zone".
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I would rather be driving
Mark,
I would dial back the cams unless you plan to modify the crank with high rpm oil mods (cross drill and grooved bearings on #5). I think that the 80 cam will make high rpm HP and the 3.0 is not quite ready for long term 7K operation. I would look at the DC43. It will pull hard through 7400 rpm before falling off. You might even want to go with the DC40 cam. Mine goes through 7200rpm with no problem - and I still lost #5 rod bearing. ![]() 46mm PMOs will be more than adequate for the job.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Consider your gearing when building your engine. That will help determine where you want your power band at.
+1 on using the PMO carbs
Can't disagree with anything here, but you may want to consider 50 PMO's for that motor if you are going to spend a lot of time in the upper RPMs.
What exhaust are you considering?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
do you have a build page on the 904?
82 SC , 72 914 |
Have you considered having Al Kosmal build you an EFI intake system? Looks retro but has all the advantages of modern air/fuel delivery.
Tru6 Restoration & Design |
