VFR750's Avatar
3.0 95mm JE piston diameter?
What is the actual piston diameter for a stock 9.5:1 95mm JE piston, measured at the inspection height?
Is it in the 94.98mm range?
I am looking at matching some cylinders and I can't find the data on JE's site.
Old 01-28-2015, 02:22 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Don at Engine Builders Supply is a good resource. He is a member here but I see he has not been online since before Christmas.
EBS_don
Just call EBS. That would be easiest. Bet he can help you. They are still open right now since in Reno.
1981 911SC Targa
Old 01-28-2015, 02:48 PM
Just received the same pistons from Don at EBS for my 3.0 rebuild. JE P/N 274048. Not sure how accurate I am with the mic but the one I measured comes in at 94.9579. Don is very helpful so should give him a call. Mark
Old 01-28-2015, 04:47 PM
VFR750's Avatar
Mark
Thanks for the measurement.
Old 01-29-2015, 06:09 AM
