CAT alternatives - punch out... straight pipe. 1980 SC
Any thoughts regarding the CAT on a 1980 SC?
TIA, Wayne
Wayne 1980 911 SC 1960 MGA 1600 |
It depends on if you want/need to keep the CAT for any reason. Do you plan to sell the car at any time? The next owner may need the CAT.
I have the factory premuffer which works well with my Flo-Pro muffler. A test pipe will probably be a bit louder depending on what muffler you install. What is the goal for the car? Track? Street?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Senior Member
Any broken material inside already (I mean, a LOT)? If so, maybe it is a candidate for a poke through. If not, put it aside and do as I did by purchasing a pass-through pipe, with new gaskets and possibly new nuts and bolts. Bring to a muffler shop and have them simply R&R the nuts and bolts. Then go home and pull the Cat for the pass-through in your driveway with new gaskets.
'78 Targa in Minerva Blue |
No plans on selling the car. Good thought re next owner potentially needing the CAT - I'll keep that in mind. You mention a factory pre-muffler - does that replace the CAT? If so, could you provide part number and/or sources. This is a street car with some DE. My thoughts re CAT are three fold - first, I need to find a small exhaust leak that a mechanic suggested might be one of the exhaust joints, second, the CAT very well could be getting a bit clogged and third, it would be nice to have a little throatier sound - not too loud though.
Rescuer of old cars
I've tried both a pre-muffler and the stock cat on my 3.2, couldn't tell any difference for normal street driving, other than the foul smells (from the stuff the petroleum companies are pleased to call gasoline these days) when the pre-muff was installed. So I run the cat now to clean up the odors.
Track use may be different, you might notice a small improvement at high RPMs.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Fleabit peanut monkey
![]() I bought the fabspeed pre-muffler. Main issue was the copper gaskets the sent with it. Would not seal where they met the cat upstream. I think I used two stock gaskets and know I used some locally bought muffler goop to seal that joint.
1981 911SC Targa |
911SC Tinkerer
I found a used Euro pre-muffler and had a shop weld in an O2 bung. Install was relatively painless except for the rusted in bolts on the cross over tube for the exhaust.
The sound is phenomenal compared with stock. I have a custom magna flow set up for a muffler. Performance wise, there was a very slight loss of low end torque (1500-2100ish) but power came on earlier and was felt evenly through out the rev range. The car also seemed to rev easier up to red line. Its more of a zing now than a slow build up. My CIS is tuned pretty good at this point, so this may help. As far as fumes go, for me, there are none to speak of but I'm using Ethanol-free mid grade unleaded as per the owners manual. I don't know if its available in CT. Its pretty easy to switch back to a cat and sell the parts you buy if you don't like they way it turns out as long as you find used bits. Good luck, -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Thanks Steve & Bob
Senior Member
This is what I am using: Bursch Catalytic By-Pass.
Eva
I'm jonesin' to know where?
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Rescuer of old cars
Here in Oregon, ethanol-free is only available in 92 octane premium, and despite the recent drop in gas prices still runs over $4.50 per gallon. My car is reasonably happy with the ethanol-infused stuff at not much more than half the price, so that's what it gets.
My premuffler is the factory installed unit with no 02 hole. Except for the muffler my exhaust is stock for a ROW SC.
I didn't see any HP gains but it sure sounds good!
I'm pretty sure some of these stations carry VP Fuels.
Locate Mercury Gas Stations | Mercury Energy Let me know if you find it there.
guys Bursch Steel Cat By-Pass, with Oxygen Sensor, 911
(1978-89) works for the carrera 1985 right? |
I'd take it to a muffler shop and have them remove the CAT so it can be inspected, then you'll know what you have. If its good, I'd throw it back on and run it. If its plugged or the catalyst is crumbling, you can either gut it or get one of the bypasses.
My car had a gutted cat what I bought it, and I have to say if replacements were less expensive, I'd run one. The car doesn't smell bad, but you do have an odor in the exhaust when its warming up. If you do go to an exhaust shop, order new gaskets and bolts from our host before you go. |
Crotchety Old Bastard
M&K Bypass Pipe versus Pre-Muffler.
Add this and chip to correct the AFRs and you get a similar increase as seen in an SSI conversion.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thanks, Wayne
Wayne 1980 911 SC 1960 MGA 1600 Last edited by heimtun; 01-26-2015 at 11:47 AM.. |
As said before, do not poke through the old one unless it is bad. Just buy a test-pipe (I've been "testing" for about fifteen years now). You never know when you may need the cat.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
