Exclamation Strange noise from right rear of car
Ok everything on this 911 is either new or rebuilt. Rebuilt tranny, new axels, new wheel bearings new brakes, new bushings etc.. new in 2011, working great for a couple of years. Its an 83 911SC.
All of a sudden it started making a thunk thunk thunk noise from the right rear. It almost sounds like a tire problem but I tried the spare and it makes the same noise. Noise is really noticeable at about 30 mph in third gear. If I speed up the noise either goes away or gets drowned out by the exhaust.
I can see nothing visibly wrong with anything in the suspension, drive train, wheels or anything and I can't figure out exactly where the noise is coming from. Anyone have any thoughts of things to check? similar experienct? thoughs, ideas?
Old 12-22-2013, 02:47 PM
Have you checked the CV joint bolts? New axles sometimes loosen up.
Kinsley
1980 SC Targa - MS2, EDIS
Old 12-22-2013, 02:52 PM
Bye, Bye.
Scooter's Avatar
CV's +1.
You might also check your shocks.
Elvis has left the building.
Old 12-22-2013, 02:58 PM
Bronze Cabriolet
lucasdw63's Avatar
Send a message via ICQ to lucasdw63
Agree. I am dealing with this problem as we speak. Just dropped my right rear axle to change the wheel side CV.
81SC affectionately referred to as "Bronze Baby" .........
Old 12-22-2013, 05:00 PM
Weird thing that happened to me: The parking brake cable end would get hit by the bolts on the CV joint as it went round. I couldn't find it at first because having the parking brake set tensioned the cable enough to keep it out of the way.
Old 12-22-2013, 06:10 PM
Thanks for the replies. I checked the axel bolts and all are tight. Shock looks fine too. Also no sign of rubbing of the bolts on the brake cable. I do notice what seems like more noise coming from the wheel side CV joint on the right side of the car then on the left side of the car when I rotate the wheel back and forth. Maybe the CV joint is broken? Shame I can't just peek under the rubber boot and take a look.
Old 12-23-2013, 07:30 AM
83 Targa
I am hearing a similar knocking sound in my '83 SC. Will have to get under the car soon for a few projects and see what's going on. I will let you know if I find a smoking gun.
Old 12-23-2013, 08:09 AM
Possibly cracked stub axle hub. Jack up the car and wiggle each rear wheel. Listen carefully for a clicking noise.
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 12-23-2013, 08:17 AM
Red face Wasn't the axle
I spent this morning swapping out the axle with a brand new one. Old one appeared fine, noise still exists. I checked the shock while I was under there and there didn't seem to be anything wrong with it. I'm getting really stumped.
Paul
Old 12-23-2013, 12:20 PM
just a thought. Check to make sure your pins retaining the brake pads are all the way in and/or the retainer spring clip is in place. The pads could be clicking if not held firmly in place. Could also be shoe for e-brake.
Tony G
2000 Boxster S
Old 12-23-2013, 12:44 PM
Wheel bearing?
Old 12-23-2013, 01:53 PM
Pulled the wheel, caliper and hub and inspected brake pads, and e-brake shoes, no problems or issues there. Everything looks fine. The wheel bearing is only 2 years old so unless it was defective it should still be good, doesn't really sound like bad bearing. And the noise only happens when its under power, accelerating or decelerating, not while coasting with the clutch in. thunka, thunka, thunka &(&(&
Old 12-23-2013, 02:44 PM
Checked all the motor mounts too, all are sound and securely fastened.
Old 12-23-2013, 03:13 PM
Only other thing I can think of is the bushings in the banana, particularly the front bushing. It could have just enough play under load to make a noise.
Tony G
2000 Boxster S
Old 12-23-2013, 04:12 PM
All bushings are only 2 years old. For the sping plates it has polybronze bushings.
Old 12-23-2013, 04:51 PM
Irrationally exuberant
ChrisBennet's Avatar
When you did your bushings, did you change the rear inner ones to monoballs by any chance? I had some and they wore out in a just a couple of years and made a knocking/clunking sound.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-24-2013, 05:06 AM
I used OEM factory replacement bushings from pelican for all bushings except the spring plate bushings where I used the polybronze bushings.
Old 12-24-2013, 08:42 AM
what about checking some weld joints?
sway bar bracket to body connection?
Old 12-25-2013, 06:08 PM
I had a similar issue in my 930. Turned out to be the trailing link arm was broken, had to source one from the factory. Expensive, but fixed. Good luck.
Careful what you wish for...
Old 12-25-2013, 09:18 PM
kbruz's Avatar
I would check the shock again. Specifically the shock tower bushings. Mine is bad on an 86 and everytime I go over a bump (which is California is now every road). I get a thump/bang from the rear end. The shock tower bushing is completely cracked and the shock tower bolt is banging around.
kb
mercedes GLK350
2009 boxster s
86 targa
Old 12-26-2013, 01:50 AM
Tags
911 , issue , porsche , problem , suspension
