-   -   proper fix for control arm mounts? (http://forums.pelicanparts.com/porsche-911-technical-forum/84978-proper-fix-control-arm-mounts.html)
haze 10-22-2002 06:40 AM
Greetings,
the holes in the control arm mounts (where the arm mounts to the body) in my 82 911 are egged out. that is, they have become bigger than they are supposed to be. that allows the control arm to move slightly in the mount which dynamically changes the allignment on the rear wheel when cornering.
Can anyone tell me the proper fix for this?
thanks
-Bryan
haze 10-22-2002 02:45 PM
i've heard that you can assemble it with properly sized heavy washers on the outsides of the mount and tack them then disasemble and weld them in place. has anyne done this or have any other reccomendations?
Jim Sims 10-22-2002 06:28 PM
Do you mean the rubber bushings or the bores the rubber bushings go into? Jim
