High Beam indicator light - not visible
Anyone have a working high beam indicator light in the tach but the plastic is so dark that it cannot be seen?
Looking for a good solution besides drilling out the old plastic and using a blue bulb. Pete |
Pete...if you solve this situation please post the results............Ron
In other words another little common defect worthy of research, almost as much fun as getting a set of hood struts to work.
BTW In the last 3 weeks after 1 set of Stabilus and 2 sets of StrongArm struts I found some Meyle struts (German) here in Canada that work!! So far that is..see if they still work in 3 weeks :) Sorry Wayne, I wanted to order your HD units but was too sceptical after all my attempts. I didn't want to chance the customs and postage :) Pete |
Has anyone solved this issue? I got some grief during a state inspection that my indicator didn't work, but the issue is that even with a new bulb, the light barely shows in the indicator.
i think this is common to the car...ditto here...they just ain't too bright.
ryan |
The light in my '86 is bright blue. No issue at all. Maybe a speedo shop would have a new blue indicator for you?
I solved this problem with an old VW turn signal warning light by installing a 6Volt bulb. Ran twice as bright as the 12V bulb.
Do the VW bulbs have the same base type? The porsche dash light base seems pretty unique, I'm not sure wher to start looking for a 6v version
Yep...just won't last very long....
You have the hood strut problem too? I ordered new ones from Pelican, and the stupid things are no better than the old ones. They just slow the hood down, they don't hold it. I need to call Pelican, since they're brand new, but unless they pay return shipping it's not even worth messing with. Meyle huh? Probably not avaliable in Great Bend KS. Ever tried the Weltmeister ones with the lifetime guarantee?
On the hood shocks, I went with Marine grade shocks used for decks and portholes. Cheaper, heavier rated and stainless steel.
Isn't that the way it is, someone ask a question about a high beam indicator light bulb, and now we are talking about hood struts?????????
I used a marine-grade high-beam indicator....:confused:
Struts
I solved the strut problem with the German units mentioned in my post...the real key to working right > 50 degree weather. I find anything below 50 and they don't hold at all.
My hood struts work remarkably better above 50 as well.
But back to the high beam indicator. I'm not much of an electrician, how long will a 6v bulb last in a 12v system? |
6V Bulb
Not very long at all :(
I'm not sure if this matters ?
I move the lids relatively slowly to Maybe help prevent leakage. I haven't had a problem, ever. |
Mike, which struts are you using? Can I get them out of West Marine? Gotta order some boat parts now that it's March....
6V Bulb Not very long at all?
TechGuy
I never had any problems with the bulb blowing? Turn signal indicator so that fact it was not on constantly maybe helped? Have you tried cleaning the blue lens from inside speedo? If you want to try a 6v bulb I'm sure I'll have one somewhere, send me a pm with your address. |
It just goes to show ya, that one thing leads to another with these great little cars we love. SmileWavy
Just a note, I was at an O' Rileys auto parts store yesterday, they carry these weird little bulbs. A 2 pack for $1.59
Cars
Hey 3.2 Cab,
I see a real mix of vehicles in your signature, didn't think anyone else mixed the exotics with the early Chrysler classics....I have a CDN 49 Dodge D32C 2 Door Club Cpe, seen many of those? I think mine is 1 of 700 since its a 2 and not a 4 door. |
Sounds like a cool ride. They had a look that was really different. I am in the process of repainting both the 53 trucks and redoing the beds. The B4B 1/2 ton is going to have polished stainless bed runners and a floor made out of Timbertec boards, stuff should last forever, about 95 percent plastic and the rest is wood products. it mills and shapes just like wood, but it will not rot. Should look good when I get finished.
| All times are GMT -8. The time now is 08:33 PM. |
