Moses's Avatar
Need thermostat education...
I think my '83 SC has 2 thermostats, right? One internal, finely machined thermostat and a second in-line mechanical thermostat in the right rear wheel well. ( I could easily be wrong about this.)
What are the opening temps for these t-stats? I presently have a trombone non-cooler. I am installing a Carrera cooler with fan and a B&B front cooler. The Carrera fan T-stat has a 100 degree switch. Do I need to change the other T-stats? I don't want to deprive my new coolers of oil till 240 degrees.
Thanks.
Old 10-23-2002, 05:01 PM
Chuck Moreland's Avatar
Not to worry. The internal thermostat starts to open around 180F, the external a little higher. Your new coolers should be well fed!
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-23-2002, 05:10 PM
Bill Verburg's Avatar
The internal and external cooler are controlled by the same mechanism ie the phase change of parafin from solid to liquid and back. In a model year they should be the same temp. There have been reports of variation however which I suspect are related to the timing where the hot oil doesn't get to the external thermostat untill after the internal one has been tripped for a while. Over the years the spec has ranged from ~80&degC to ~87&degC(~176&degF-~189&degF) The temperature of the phase change can only be changed by altering the chemical composition of the parafin.
The Carrera cooler electric fan comes w/ a thermstat that trips at ~188&degF this temperature can be altered electrically but since your car will be overcooled a manual switch would be as usefull. The mod consists of a different thermoswitch which is available in 110, 99 or 91&degC versions which are all available here at Pelican Thermoswitchs I would stick w/ the standard thermoswitch until I observed that there might be a problem somewhere down the road(not likely w/ your setup)
Bill Verburg
Old 10-23-2002, 06:15 PM
Moses's Avatar
Bill,
I got the 91C switch from Pelican. Now I'm wondering if I might run too cool. Guess there's no such thing. Just drive harder.
Old 10-23-2002, 07:47 PM
