-   -   Instant G Crate in middie? (http://forums.pelicanparts.com/porsche-911-technical-forum/850823-instant-g-crate-middie.html)
Spumato 02-09-2015 08:01 AM
Do any of you know if you can put a 3.6l crate into a 1974 Coupe w/ a 915 transmission?
And does anyone have experience with Instant G? I am just trying to evaluate options on replacing my 2.7.
tirwin 02-09-2015 08:15 AM
I know for a fact that you can mate a 3.6 to a 915. Not sure about any fitment issues with a 74 chassis. By that I mean, that it can almost certainly be done but there's probably a list of things you need to know about and work around a bit to do it.
PM Grant (Uwanna) for some advice. He put a 3.6 in his SC back in the '90s before it was a common thing. He's been trying to convince me to do the same. :)
I seem to remember reading something about Patrick Motorsports doing that job too. Somewhere I saw a list of all the modifications that were needed -- don't remember if it was here or on their website or someplace else.
Bill Verburg 02-09-2015 08:19 AM
I had Steve put one of his crate motors in my '76, I did have him rebuild it though. I was very pleased w/ his work and communication.
tshebib 02-09-2015 08:27 AM
I used Instant-G (Steve) for all the required conversion parts.
He's very helpful and made the process very easy.
Open up his "Cost Estimator" and study it to death.
Here's the link to my conversion/slippery slope.
http://forums.pelicanparts.com/porsche-911-technical-forum/645203-finally-registered-pelican-introduction.html
The list of parts I used is on the first page.
Best thing I ever did...it totally transformed the car.
Tom
froggert 02-09-2015 08:37 AM
using instant-g's conversion kit and one of his motors, i was able to swap the 3.2 in my '87 for a 3.6 and have it up and running in a weekend. there are still some small things to do (like mounting the second oil cooler), but it was basically plug and pray.
wildcat077 02-09-2015 09:33 AM
You'll need to buy a load of conversion parts anyways,there are a lot of pre 80's cars with 3.6's
running around !
Steve will answer all your questions.
Cheers
Phil
JeremyD 02-09-2015 09:56 AM
Yes definitely doable - I have a 3.6 with a 915 (although a later, stronger 915 with the 8/31)
Hoss911sc 02-09-2015 10:01 AM
Instant-G installed a '95 3.6 crate motor with Varioram added for me along with a second oil cooler. Steve does quality work and provides excellent support as well. The increased power and torque (especially low-mid) transformed my driving experience.
As a bonus, the exhaust sound is fantastic and addicting :)
APachon71RN 02-09-2015 10:40 AM
What did a drop in 3.6L cost you guys?
Bergo 02-09-2015 02:13 PM
full setup from instant G gets close to $20k w/ exhaust
dwight45 04-14-2015 12:23 AM
How much for the conversion labor? I'm in the same mood.
froggert 04-14-2015 08:42 AM
it cost me a weekend's worth of beer and pizza for several friends. i'm convinced one showed up just for the food and to hang out as i never saw him near any tools. :cool:
gliding_serpent 04-14-2015 11:15 AM
I dont have a 3.6 conversion (i went 3.4) but i can tell you domething a wise man told me:
3.6+915=$$$
Be prepaired to reinforce your 915. Clutch, bearing retainer plate, reinforced diff side cover, heavy duty (possibly longer) second gear, ideally robust 3rd gear.
Then prepare to upgrade your brakes, and oil cooling. Then comes the suspension to put all that power down. Sticky rubber too. Larger wheels for your larger brakes?
Costs add up. Done right, and you have a car that will be killer fast.
Steve@Rennsport 04-14-2015 03:05 PM
Originally Posted by gliding_serpent (Post 8576452)
Be prepared to reinforce your 915.
Stellar advice and all of it true. :) :) :)
Sure perks up these older (light!) cars, though.
Jack Stands 04-14-2015 03:21 PM
Since all these engines are now getting old and in need of rebuilds (at least many are), have you considered simply rebuilding the 2.7? Henry Schmidt @ Supertec did mine with RS pistons, Webers, and some S cams, and it makes nearly 200hp at the rear wheels.
However, the Motronic fuel injection is sweet!
Busta Rib 04-14-2015 04:16 PM
This conversion is also on my Porsche bucket list and I plan on giving Steve a holler when I am ready.
Joe Bob 04-14-2015 04:34 PM
Had his motor over ten years. He's good and delivers. He is slow, crusty 'tude and his exhaust systems are way over priced. Other than that, carry on.....
