Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
81SC - need help with rear fuse wiring
I have an 81 that came without the metal mount that holds the CDI unit, Defroster Fuse, and the engine harness plug. I had to source all the bits and pieces from scratch to put all this together. In any event, Im at the point where I have to wire up the 3 block fuse panel. Can anyone take a look at how this is wired up on a stock setup and hook me up?
the wires I identified are as follows based on the picture and how I was positioned:
Left Side: big red wire and a little red wire
Right Side: big red wire, red with white stripe, red with black stripe, blue with yellow stripe
Thanks!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 02-11-2015, 01:23 PM
ghamilton's Avatar
I'll try and remember to pull the cover off my 82 when I get home.
If I can get down my driveway!
Read 70+" snow in last 25 days..
This is before the 24" we got this past Monday.
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 02-11-2015, 02:19 PM
Black and Blue
Kemo's Avatar
OMG!!! hope your heater works!!!
Kemo
Old 02-11-2015, 03:07 PM
ghamilton's Avatar
Yup, nice and toasty in garage.
Hope this helps.
G. Hamilton
"Bumerang"
'70 TR6
N of Boston
Old 02-11-2015, 03:22 PM
El Duderino
tirwin's Avatar
One of those red wires on the left side of the fuse panel in the picture above is constant power and the other is switched power. I'm pretty sure the top (with the copper bridge to the middle fuse) is constant and the bottom is switched. You'll have to put a voltmeter on them with the car off to figure out which one is which.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 02-11-2015, 06:23 PM
chadco's Avatar
1979 rear fuse pic.
Here is mine, it is a 1979
Old 02-11-2015, 07:14 PM
chadco's Avatar
whoops forgot pic
Old 02-11-2015, 07:17 PM
Black and Blue
Kemo's Avatar
so from the pic, it looks like Big red to top, little red to Bottom on the left side. But the big kicker here is constant vs switched...constant on top.
and it looks like Big Red to the top, red-white stripe middle and the other two bottom...on the right side
does that sound about right?
Kemo
Old 02-12-2015, 06:09 AM
In case you didn't see one there should also be a short 6" brown ground wire from that aluminum consul to the ground stud
Lorne M
83 SC
Old 02-13-2015, 10:47 AM
