Jacksonville, Fl
HOT Air through Driver side foot and dash vents.
Earlier this week I took my '88 out for a nice drive. I've known the AC has been due for a recharge, so I wasn't expecting crazy cool temps in the cabin, but after 20 minutes or so into the drive, I noticed that the foot vent and the far left dash vent were blowing HOT (really hot) air, but only at highway speed. My first thought was that the drivers side flapper box under the car was stuck closed, forcing air from the HE's into the cabin. Nope, those are working as they should and both sides were fully open.
Important details to note: 1. the hot air is blowing only through to outlets, the drivers side foot vent, directly under the steering wheel and the dash vent to the left of the ignition. 2. This only occurs at high speeds >60mph 3. This only occurs when engine is warm (obviously) My first thought is that there must be a vent somewhere that is forced open with the added air flow that occurs at higher engine speeds. IDK Any thoughts where I should look next? Thanks Alex
Alex Jacksonville, Fl '88 Carrera, Guards Red |
Member 911 Anonymous
How did you check the flappers, with a helper or by yourself.
Strange, if fully closed it should be sealed. Do you have auto heat or standard heater control?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Jacksonville, Fl
Draco, I didn't have a helper handy, but I was going back and forth between the cabin and under the car using the red levers to test, and it seemed to work as it should. I do have the automatic heat which has stayed in the off position.
Seal has perished in the flapper box and/or the spring isn't fully closing it. Only takes a tiny gap to get hot air through.
www.classicretrofit.com |
Banned but not out, yet..
+1. Had the same issue. Perished Seal.
An air cooled refrigerator. ‘Mein Teil’ |
Jacksonville, Fl
Thanks for the help guys. I'll add that to the grocery list...
