3.6 conversion idle problem/ECU help
Thanks for any advise in advance- I've been trying to figure this out for a while and I could use some help.
Background: 95 993 3.6 swapped into a 74 911 Originally a tiptronic engine Cintex chip Older Patrick motorsports wiring kit Problem: I installed the engine and have had this problem from day 1. With the ISV plugged in the car idles anywhere from 2k -3k rpm. After DME reset it will start fine, idle around 1200, then clime to 2-3k rpm and remain. After warmed up it will idle fine with the ISV not plugged in, there is very little hunting but I don't have a massive vacuum leak that I can find (lots of time searching with starter fluid and smoke) -I replaced the ISV with a brand new one, no change ($$). -TPS seems to be working within tolerance. -Throttle is returning to closed fine -Ive gone through the DME plug, all looks normal. -SAI removed, but that was after the problem had begun. -I wired the check engine light (ground from pin 8 on T-16 plug) and so far I get nothing (which seems strange because I have a chip?). A couple questions: 1- When all sensors are plugged in I get a loud hum from the engine. With out the ISV plugged in I do not. Is that normal? 2- Could it be the chip or DME? 3- Any other suggestions? I'm stumped and would really like to have a car that idled cold and so would my neighbors :) |
Have you plugged in an OBD_II code reader to see if there are any stored codes?
Have you put a volt meter or oscilloscope on the ISV wires to the DME while the car is running? Perhaps one of them is shorted in your wiring harness and holding the ISV open? Keep us posted on what you find, Chuck.H '89 TurboLookTarga, 391k miles |
Hi Chuck,
It's an OBD-I engine. I did wire the check engine light but it is either not working properly or not throwing any codes. I have not checked the ISV voltage, good idea. Is it supposed to be around 9 volts? Sadly I do not have access to a O-scope, but could. What would I look for? thanks -s |
A couple of pointers:
- any chip where the ckecksum has been calculated correctly will NOT throw a CEL. - the CEL needs to be on when you turn the ignition to RUN without starting the engine. If not you didn't wire it correctly. Remember the DME supplies GND when it wants to turn the light on. The other side of the bulb needs to be connected to permanent +12V. - the CEL can be used to "flash out" DME failure codes in the absence of a Hammer, PST-2 or similar - pretty useful. - if the engine came out of a tip or manual doesn't matter. Chances are the Cyntex chip has all pointers bent to look at the manual maps only. In addition you should make sure the harness has the correct version coding. It tells the DME whether to be a tip or manual version. With regards to the idle issue can you make sure the engine dies when you plug the ICV intake. If not then something is seriously wrong. Think of the ICV as a variable bypass of metered air. In other words it acts similar as if you would crack the throttle plate open ever so slightly. That being said the throttle plate stop has to be set in such a way that the engine idles at 880 RPM with the ICV in its mid-point. That will allow the ICV to influence idle in either direction to make sure it'll stay around 880. In you description is wasn't clear whether the engine idles fine with the IVC port on the intake downstream from the throttle plate being open to the atmosphere or being plugged. Next, as yours is a transplant have you made sure to properly deal with the vacuum plumbing normally intended for the brake booster? It needs to be plugged, else it acts like a giant leak. A tester will allow you to read out what the ICV commanded position is. In addition to that you need to make sure the ICV driver is working so that the ICV actually moves. The output is not a constant but a duty-cycle modulated pulse train. So you need an oscilloscope to properly test. Or a tester that actuates the ICV against its stops. Regards, Ingo |
Ingo, Thanks so much for your reply.
To address your points: - I have not plugged the ICV down stream of the butterfly. If I unplug it when the engine has been warmed it will idle fine. I will try to plug it tonight and see if I can get it to run. - I have little doubt the ICV is moving, the slow increase to 3k RPM must be from the ICV opening... at least I can see what else is raising the idle so high. - All vacuum ports have been plugged (brake booster included) with smoke and starter fluid I can find no leaks. I'll try to borrow an o-scope to get a reading.... but what should I look for to be in spec? thanks again! |
Here are a few thoughts after I recently was having idle troubles with my OBD1 3.6 VRam engine:
1. How old is the Cyntex chip? If it's an older chip it may be defective. There was a bad batch of chips years ago, some of which are still in use. They cause all sorts of issues including high idle. If you don't know the history of the chip I'd consider swapping the chip for a different chip (stock, Steve Wong, new Cyntex, whatever). 2. Have you performed an idle adaptation after leaving the battery disconnected for 24+ hours? Another way of doing the idle adaptation is simply let the car idle for 20 minutes or so after getting the car up to temp, although I've had better luck with Steve Wong's version in the link. 3. If you haven't cleaned the ISV I suggest doing so. A clean ISV is more responsive vs. a dirty ISV. Also do a search on making the ISV adjustable. While the DME actually controls the ISV you can manipulate the open/close point within the ISV to help fine tune the idle. 4. My DME seems very sensitive to voltages. I have a parasitic drain on my battery when the car is off due to the window relay staying energized. If I don't leave a battery tender hooked up then after a few days the DME seems to lose the idle adaptation (or it makes the engine idle high to help charge the battery). I haven't quite figured this situation out (need to eliminate the parasitic drain) although keeping the battery in proper order seems to take care of this issue. In other words - if your battery voltage is low you may be chasing an idle problem due to the low battery. To summarize - with my car cleaning the ISV, performing Wong's idle adaptation, keeping the battery charged, and verifying no vacuum leaks has produced an acceptable idle. |
Oops sorry thought they had OBD-II by then, my bad. I shouldn't even be responding, as I'm only familiar with the engines I own :-) Ingo's advice is good, the CEL should still come on when the power is first applied to verify it's working.
On some ISV's they are controlled by square wave signals, essentially a 'duty cycle' of on and off, which causes the ISV to flutter around a certain opening. If this is the case here, then you can clearly see this duty cycle with an O-scope, and see it fluxuate as the throttle is opened and closed if all is correct. Have you considered you have some other sensor failure that is causing a 'limp mode'? Many ECM's will raise the idle in limp mode. Hope this helps, sorry for Porsche's I only have 3.2. Chuck.H '89 TurboLookTarga, 391k miles |
Couple of possibilities
1) the chip try another, Ingo's No Bad Days and 911Chips might be good choices 2) the DME for a tip is different from a manual. The tip DME gets a signal at pin42 of the DME from the gear selector. In P and N the the control is connected to ground, In any gear the ground is interrupted, this is supposed to lower the idle rpm from 800 to 750. There is also a meshing signal at pin 51, the signal comes from the transmission when it changes gears, this signal is supposed to retard the timing a tad to ease the shift. 3) to do adaption all you need to do is disconnect the battery for a minute or so. Then restart w/o touching the gas pedal, this sets the throttle base position, let the engine idle for 15-20 min. It doesn't hurt to redo this. |
Forgot to add the other Tip specific pins in the DME, these are unused in a manual
42 tip stepping switch -I'm not surr what this does 44 tip coding tells the DME that it's a tip 52 PWM(throttle position sensor) a manual uses pin 52 which is the signal from the throttle pot. |
Thanks for all the suggestions. A little update:
1)Preformed the idle adaptation. No change. 2) Will not idle with the ICV plugged. I plugged the ICV on the engine side and it will not idle cold. I let it warm up. Plugged it again and it will not idle. 3) I'm reading 12.3 volts at the ICV middle pin. I though it was supposed to be lower? 4) I removed pin 44 from the DME- No change 5) The humming noise I mentioned earlier is the ICV, it is vibrating to the touch. Both the old ICV one and new ICV do it when plugged in. Is this normal? 6) I'm reading 14.2 volts when running at the DME. Ground seems good. 7) CEL is wired correctly as ground to +12v source. I have it to the green and grey wire on pin 8 of the T-16... sound right? I'm beginning to suspect the Cintex chip. Anyone have a stock 993 chip to lend out? A new NBD or Wong chip is just too much money to buy just to try. Any other thoughts? |
The ICV shouldn't be noisy in operation, if you have it in you hand you can make the flapper slap against the stops
The ICV is just a twin coil positioner, the DME(stock chip) asks for an 800rpm idle hot 1100rpm cold The positioner is supplied w/ 2 clocked electrical inputs from the DME, pin 4 is + to open, pin48 is grd, pin 49 is + to close This creates opposed torsional forces on the armature. Due to the intertia of the armature the positioner adjusts itself to a particular angle that corresponds to the pulse/duty factor of the signal received By modifying the input signals when the engine speed changes, the pulse duty/ factor of the signal supplied to the positioner changes as well. Th programmed nominal rpm is compared to the actual measured rpm . The air flow is then modified by the positioner until the nominal rpm and actual rpm are within the defined rpm envelope. when you look at the plug at the ICV the center terminal is battery voltage, the Left and Right are the + duty cycle signals which will vary from 0 to battery voltage but they will be opposite each other so the signal across them should be from +battery V to - battery voltage, ie -13v to +13v, an oscilloscope will show a square wave ~5ms wide, -13v to +13v There should be a slight audible pulse. Another possibility is some other fault in the DME, we are seeing more and more degradation of the solder connections and plastic parts in the DMEs, these will require a rebuild, ECU doctor in Fla is very good. |
is the open signal, but pins 48/49 are the reference signal pins from the speed sensor. The close air valve pin is pin 22. The center pin to the valve is 12 volts. |
pin 4 is idle open pin 22 is idle close the center pin is battery voltage it is energized from pin 37 which also energizes terminal 87 of the DME relay and the resonance shift flap terminal 2 Pin 48 & 49 are engine speed sensor |
So I started digging into my harness to look for shorts.... And I found this (pictured)
It's some kind of transformer coming off of pin 4 on the t16 plug. Goes to purple and black on the dme side. Car will not start with out it plugged in Thoughts???http://tapatalk.imageshack.com/v2/15...e5622bbbf0.jpg Sent from my iPhone using Tapatalk |
Scratch that, it is for the tach. Not sure why though....
Finally took the ecu out. Nothing obviously cracked.... But this strange.
Normal? Sent from my iPhone using Tapatalk |
http://tapatalk.imageshack.com/v2/15...f1cbfe7fd3.jpg
Attachment problem: Sent from my iPhone using Tapatalk |
Next question. What chip is this?http://tapatalk.imageshack.com/v2/15...b04bdd720e.jpg
Not sure what you refer to as "strange". The white stuff is glue to support the resistor and normal. It's applied to reduce vibration impact causing stress fractures in the solder.
The second picture shows the aftermarket EPROM (aka: chip) with the paper label in the 28-pin DIP socket. |
That looks like a FVD chip, not Cyntex.
FVD, Porsche Tuning, Motorsport, Accessories, Motortuning, Sportfahrwerk, Felgen, Bremsen, Leistungssteigerung, Boxster, Carrera, Turbo |
Ingo- Thanks! I've never seen anything like that on a board. I was worried it was an addition.... looks kind of shotty :)
Kaefer- Thanks as well. I could not decipher writing.... know anything about their 3.6 chips? I have an email into them to get some info. |
IIRC I believe Ingo also offers some nice DME chips! :cool: |
Oh I've been reading about Ingo's chips... very cool :)
I just want to be sure that this is my problem before I throw more money at it. I'm trying to find another ECU to swap in to be sure. |
Just curious, but why does this DME not have the gob of silicon?
http://forums.pelicanparts.com/5871624-post7.html |
Here's one of my 55pin 993 DME's, they both look the ssame to me, except for the chips which I installed
I think that this is the '97 RoW http://forums.pelicanparts.com/uploa...1424989430.jpg |
In the OP's DME an axial resistor is installed in place of C232. Not sure about why but my assumption is that it helps bleeding off charge in some filter capacitors when the DME is shutting down. Bill's DME doesn't have this resistor. Could be a different revision.
Ingo |
the codes for both are in every unit and are accessed by varying the connections between pin2 and pin 54 2-54 open is RoW 2-54 connected is US 2-54 w/ 1kΩ is for the leaded gas no O sensor versions 2-54 w/ 14kΩ is for RS all have a user removable chip I have used the one in the picture to control both a US 95 non vram and a RoW '97 vram I did have to have it rebuilt last year as some of the plastic components and solders were failing. |
I suggest putting an o-scope on the 2 ICV signal lines. You need to know what the duty cycle is telling the ICV to do. The signals are 2 square waves that are 180 degrees (opposite) of each other. So if one is 25% off and 75% on the other is 75% off and 25% on. I've seen a few 84-89 DMEs with a drive transistor shorted so that one of the lines is shorted to ground.
Would be nice to know what the signals on the 2 lines look like. Also test the ICV, search for "bench testing idle control valve" in this forum. |
Can you try another chip to see what happens? I've got one out of my '95 Carrera you can have for the price of shipping. I think it is aftermarket (came with the car and got replaced with a Steve Wong chip).
there are component differences on the two circuit boards. There was a reason for labeling the one ROW and not other, and that would not have been the case if changes were only made by external jumpers. |
If you need a 1995 993 chip I have 2 bin files I can burn
the 164 - M04MOTRONIC9936181230202612031631267358164 or the 948 - M04MOTRONIC9936181240402612036751267358948 I assume the 948 bin is the latest but I'm not sure. If you can't locate a factory chip I can burn one for you, PM me if you need help. One more idea: do you have access to test your DME in another car? That would be helpful. |
Thanks for all the replies guys.
Last night I went throughout the entire harness looking for problems. Cant find a thing. I think I tracked down an o-scope so I'll try it this weekend and report back. Thanks for the offers on the chips I'll PM. It would be good to have for trouble shooting. |
Just got this back from FVD regarding their chip:
"Chip is today same like 99. It is non Vario EU DME without immobilizer CU. Octane rating should be 98 (EU DME). Could work also with less but also with less power. There is no any changes on idle" So obviously the octane is way off.... Since there is not change in the idle settings could the light weight flywheel be causing the high idle? 3,000 rpms seems a bit high though. Guess its time for a new chip! |
There may have been evolutionary changes from '94 to '98 but they all are functionally interchangeable through the 2 pins and chip Of course the turbos and US from '96-98 are different, they are 88 pin, in fact '96 was different from '97/98 wrt to hardware but was still interchangeable. |
Put a stock chip in the DME, see if it solves the problem.
Even with light flywheel it could stall when returning to idle but once at idle should idle fine. Quote:
98Euro= approx 93.5 US check this:Octane rating conversions - PencilGeek's BMW Blog |
my first problem was hunting, Bill V. helped me with the diagram of V-ram
second was my ISV I cleaned it 3rd problem was 02 censors was not plugged in, I bought harness plugged it in vola no mo problems, good luck |
| All times are GMT -8. The time now is 09:36 PM. |
