oil line & tank cleanup?
Getting everything ready for my new motor from the good Doctor Timmins. How much effort should I put into cleaning out the oil tank and lines? Remove and take somewhere for a kerosene bath, just blow the lines out with air or leave as is?
Front trombone worked fine, got hot, with my 3.0L. Does crud build up in these lines?
Rob Fix '78 3.6L SC Targa Eiche Gruen Metallisch |
Schleprock
The lines and tank were exceptionally clean on my car when I removed them last winter. My car has 66K miles on it, so it might not be a good guinea pig.
The tank only had a slight film of what looked like varnish on the inside. A rinse with brake parts cleaner washed it out just fine. I'm sure kerosene would do the same. I also removed the fender thermostat lines and cleaned off all the crud that was put on there from the factory. A look inside these lines showed no signs of sludge/crud buildup either. So, if a visual inspection of your lines and tank doesn't reveal anything, there's probably no reason to think there's some sort of buildup in there.
Kevin L '86 Carrera "Larry" |
Senior Member
One exception. If there was internal damage to an engine, then all oil lines and coolers must be cleaned. Professionally, probably. I think our beloved Tyson Schmidt had the pleasure of rebuilding a 911 engine twice while learning this lesson. Bits of metal will be in those oil passages if the engine was damaged.
If not, then just inspect and reinstall.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
If you are worried about it, take them to a radiator shop and get them cleaned out. They can do oil coolers, tanks and lines and its worth the time and trouble if you are not sure of their condition.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
