Slantnose Parts?
I am restoring my slantnose and and looking for body parts. The person that owned it befor me painted all the rubber body parts. I am looking for the the rubber strips that go between the body panels.
Any websites that sell after market parts for these kit?
1969 911, resurrected into Widebody Slantnose Cabriolet
Old 03-09-2015, 06:04 PM
petercory
Check out our hosts catalog or download a copy of the PET catalog to help identify the part numbers of the items that you need; most are probably still available and can be order from a dealer.
Old 03-10-2015, 04:30 PM
Can't seem to find anything in hosts site. What is PET?
Old 03-10-2015, 05:15 PM
83 911 Production Cab #10
JJ 911SC's Avatar
PET is the Porsche Part Catalog fo all they Model/Year. Not easy to navigate but give it a try: http://www.pelicanparts.com/PartsLookup/Parts_Lookup_Main_Page.htm
You can always post a photo of the part you need and someone will pipe up.
Who Will Live... Will See
Old 03-10-2015, 05:24 PM
If the rubber parts are still good but covered in paint, maybe you could strip the paint off?
Rutager West
Old 03-10-2015, 05:31 PM
No one seems to be able to tell me how or what to use to remove the paint. A razor blade on all rubber would take many, many hours to do. Rubber is fine under all the paint
Old 03-10-2015, 05:41 PM
wrxnofx's Avatar
I used lacquer thinner and Qtips on all the overspray places where the idiot PO had the car painted without removing things first. If the rubber is hard like the bellows, I would think this would work just fine (I still have to remove the overspray from mine). I used this procedure on the rubber seals around all windows and it works. It just takes time. You could also try the hard plastic trim removal tools. I think you'll find it'll start chipping off the rubber if it is flexible at all. If it's hard plastic like fog light covers, it takes time and a ton of Qtips because the paint doesn't chip and has to be rubbed off.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 03-10-2015, 10:21 PM
