-   -   CIS - Differences between WURs (http://forums.pelicanparts.com/porsche-911-technical-forum/852863-cis-differences-between-wurs.html)
Jay Laifman 02-22-2015 08:03 AM
I have a 73.5 CIS 911. I've had it for 26 years and over that time, the original WUR was replaced with an 009. I still have the 001 in the garage. My car has been having a cold starting and initial running issue and I'm trying to track it down. In the meantime, I've always wondered if I should get the 001 fixed, or made adjustable.
The curves are not the same, so I've aways thought that perhaps my car is not running as optimal as it should. When I compare the 001 chart to the 009 chart:
001: 1.4-1.7 bar @ 10* to 2.5-2.8 bar @ 35* (range of about 1 bar)
009: 0.5-0.8 bar @ 10* to 2.0-2.4 bar @ 35* (range of about 1.5 bar)
Doesn't this mean that I'm running too rich or too lean at one end or another? FWIW, I just measured mine and I'm getting .5 bar (cold) to 2.9 bar (fully warmed up). So I'm even higher than I should be, meaning I'm richer when cold and leaner when warmed - I think. Does this negatively impact the 73.5?
FWIW, after sitting for 12 hours overnight, my car does not like starting in the morning. It has to spin on the starter for too long, and it runs rough for 3 minutes or so. But, interestingly, 12 hours later when I'm leaving work, after it sat for the same amount of time, but in a warmer garage, it starts fine and runs fine immediately.
fanaudical 02-22-2015 09:04 AM
The WUR's are matched to the fuel distributor and air sensor assembly. Swapping any one of those three components from what is intended can create poor running conditions. I think you're correct in your assessment above. I think the 009 references manifold vacuum (which I didn't think was the case with the 001) and so you've got some added complication there.
There are a couple of posters here on the board that do a great job with WUR rebuild and testing. I had mine done this winter by Tony (user: boyt911sc ) and things work great!
jason2guy 02-22-2015 11:08 AM
sounds like its too lean when cold. according to the specs above the 009 runs richer on startup than the 001- if its in spec. you need to put some gauges on there and test the fuel pressure. its probably out of spec creating a high control pressure situation when cold. ive never opened up an early WUR but im sure a mod can be done to adjust it. ok i didnt see you did check pressure, 0.5 bar when cold is going to be too rich. it should be 3x that.
Jay Laifman 02-22-2015 11:11 AM
Thanks. I did put a gauge on. I am at .5 bar at cold and 2.9 bar when warmed.
So that should be on the rich side at start, right? If anything, richer than a "stock" 73.5 CIS. Wouldn't richer usually make it easier to start? Or could it be too rich?
jason2guy 02-22-2015 12:32 PM
thats what im thinking, too rich. usually a hard cold start ends up being too lean.
does your car have an additional throttle valve setup thats tied in to the WUR?
Jay Laifman 02-22-2015 12:37 PM
Yes. But to tell you the truth, it doesn't seem to be doing anything. I watched the gauge as I pushed the throttle all the way to WOT and back to idle. Nothing changed. As I understand it, it should go rich at full throttle and no throttle.
If I recall, when I had issues with my WUR years ago, and I went through all this before, it might have had the slightest of impact. I know I bought another TPS, but I can't remember if I swapped them. I need to pull out that other one.
Hil911 02-22-2015 02:04 PM
Sorry if I'm out to lunch, but does the 009 use a TPS? I can see that the 001 does but I thought that the 009 would just use vacuum?
Jay Laifman 02-22-2015 02:12 PM
My 73.5 has a TPS on it. The TPS does not connect to the WUR. When my WUR went bad, the guidance I received then was that 001s were no longer available, new or rebuilt, and that the standard was to put on an 009. I do not recall anything about disabling the TPS. So, no, I do not believe the stock cars with 009s had TPS on them. But, I to my knowledge, 73.5's that have had their 001 replaced would be running with both.
jason2guy 02-22-2015 03:27 PM
if you need help with it come out to venice and im sure we can straighten it out
Jay Laifman 02-22-2015 07:24 PM
I happened to have a long call with Larry at CIS Flowtech.
He asked, and it turns out, that my TPS is disabled. He also said that the air plate is supposed to be adjusted to match the cone where it straightens out, on the FAR side from the distributor. Mine was adjusted on the close side. He said that there is no way to rebuild the original 001s. With the 009 in my car, though he said I'm missing the part that leans and richens it from the vacuum, and that that would make a big difference in the running.
The problem is that he didn't know how to get a vacuum line. He said to check out how the 75 911s do it. He also suggested possibly pulling vacuum of the distributor vacuum line. But I'd be worried that would interfere with the action of the distributor, and probably not be enough vacuum for the WUR. Anyone have thoughts on that one?
Meanwhile, I did find that one of the rubber joints on the bottom of the air box was pretty loose.
But notwithstanding attending to all these, at this point, my car isn't starting at all. Ugh.
Jay Laifman 02-22-2015 08:03 PM
I should add that he also said that with the vacuum added, like about 15" of vacuum, I should instead see 1.4-1.7 bar when cold and 3.4-3.8 bar warm.
Hil911 02-23-2015 01:08 AM
On mine the WUR is vacuum T'ed on the lower vacuum outlet, as is the distributor. Neither unit should leak vacuum, so they can share it fine.
Yah, the TPS didn't attach to vacuum but it fed back to the WUR control pressure in a manner analogous to the vacuum on later models.
T77911S 02-23-2015 03:14 AM
you can change the throttle body to get the vacuum port. even better put a TB from a 3.0 on because it is bigger. i put a 3.0 TB on my 77.
JMO
the curves dont really matter. if you notice, porsche started doing more to lower the cold pressure to make cold starts better and to eliminate the backfiring when cold. look at the vacuum controlled WUR's. they will drop to .8 bar with the thermo time valve (TTV).
(the chart shows above 1bar at its coldest but that is with vacuum. without vac the pressure drops about .8bar)
i would rather have a low cold pressure any day.
boyt911sc 02-23-2015 05:37 AM
Correct information........
Jay,
Larry has given you the correct information (partial). If you have a good working WUR-009 that's the way to go and get rid of the TPS. I am presently away from home and in Sydney, Australia right now. I could test your WUR-009 for free if you could wait till I get back home. The first thing you need to do is test and calibrate your WUR-009. PM me if you need some assistance.
Tony
Jay Laifman 02-23-2015 08:06 AM
Thanks for all the thoughts and suggestions. I have some comments back:
(1) This goes back to my physics classes, and I don't remember. The hose size for the distributor vacuum is smaller than the one for the WUR. If I was to T it, and have to step up the size for the WUR, that creates greater volume, and from a smaller port. Does vacuum still stay even across, like pressure? Or is the vacuum some how robbed or limited because of the smaller size of the port or because it is now serving two devices?
(2) I always thought that adding a larger throttle body was not necessarily a good thing for these CIS cars. I've read many times over the years that it's a big no-no to swap parts - and that this WUR swap is only out of necessity. If this is ok too, anyone got a '75 TB for sale?
(3) If someone takes an 009 and makes it adjustable, and adjusts to top end and bottom end to match the 001 curve, is there any difference between them? And if not, why not just run with a TPS and not the vacuum?
Thanks!
prebordao 02-23-2015 08:10 AM
Jay,
I have a 74' 911S, that originally came with the 001. As others have said is not rebuildable, but it has some degree of adjustability, both for warm and cold pressures.
Due to old age, mine started getting out of spec and outside the limits of adjustability.
As I like to try "new" things and I'm handy with electronics, I decided to replace it with a digital controlled WUR. Not everyone's cup of tea, but it can be programmed for any range of pressures.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/820323-digital-wur-plus-frankencis-13.html#post8388089
Since then, cold and warm starts (and restarts) are a non issue.
Jay Laifman 02-23-2015 08:16 AM
I've heard about something like that. Is it able to become variable based on idle/WOT or on vacuum too?
prebordao 02-23-2015 08:22 AM
Yes, it can support that. You'll need an additional sensor, either for vacuum or Throttle position, of course.
I just left my TPR plugged in as normal, although when I measured, it wasn't doing much.
However, the TPR main effect is to lean the car in the midrange (for emissions and mileage, I suppose), so it's not a big "deal"...
T77911S 02-23-2015 09:15 AM
1. you are over thinking it. it does not matter. its still going to pull vacuum to operate both.
2. the bigger TB may give you more in the upper RPM's or at WOT. it wont matter for normal driving. my 77 2.7 ran fine with it. i could not really compare before and after because i had some other issues that limited my power before i swapped.
i know in some rule books for SCCA it talks about larger TB's putting cars in a different class or they are not allowed if that tells you anything.
all the TB is doing is controlling the amount of air coming in. it is not like a carburetor that is using vacuum to pull fuel from a bowl. also at WOT it is a restrication compared to a larger opening.
3. this is my take on the WUR warm up curve.
dont worry about it. set it for the WCP and just check the CCP for the WUR.
if you start trying to either limit how much change there is from cold to warm or expand how much change there is, it may mess up things for the WUR. IE, if the pressure goes from 1.5bar to 3.6bar and you try to make it go from .8bar to 3.6 bar, the WUR may not be capable of doing that. so just set WCP for the CIS and the CCP for the WUR spec. (actually for the difference between the 2). if CCP to WCP is 2.5bar, maintain that. that is what i would shoot for if i had to use a non original WUR.
i dont remember how the TPS works for the older cars. the vacuum may be more simple, plus with the TTV you could drop the CCP even more. that could be good if you live up north.
not trying to talk you into anything, just giving you ideas for what you can do or how to do it,.
Jay Laifman 02-23-2015 10:16 PM
Thanks for this further information.
I don't know if you saw the other thread I started looking for how the 009 WUR vacuum is hooked up. Some guys posted some great pictures of the T that goes into the bottom of the Decel Valve, sending the hose over to the WUR.
Larry at CIS Flowtech seemed to think that I'd see marked improvement by adding it. So now that I know what the part is, I tried to find it in the PET, but couldn't find it. So I've emailed my local Porsche dealer parts guy to see if he can get it for me. I'm game to give it a shot.
