Shifter throw on a 915
What is the approximate normal or "good" distance of play of the shifter when the transmission is in gear? Is any excessive play typically caused by the shifter bushings being worn?
Would worn bushing cause random balky/"sticky" shifting? Notchy shifting? (yep, I've done the search, have a good idea, but am am still wondering...) Thanks. |
Member 911 Anonymous
It sounds like your coupler is wearing out. Have you ever replaced it?
It may feel tight in your hands but when you get a new one or even better get a upgraded one like Coupler Whisper's coupler. You will feel a huge difference. I would not hurt to inspect the bushings, those are probably worn as well.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
Yep......bushings and/or coupler.....transmission and engine mounts can also be a factor.
If you have ever had your hand on the shifter lever and blipped the throttle and it gives feedback....it's mounts.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanks guys.
The shifter doesn't dance when I hit the throttle, but the shifting just isn't right. I've never replaced or worked on the bushings in the coupler/shifter, the vehicle has 86,xxx miles or so. I'm convinced it's original. Thinking I would get after this project this past year, I do have the rebuild kit our host sells - sitting on the workbench. Understanding that the coupler whisperers bushings are a good product, would you recommend that I order his, or go ahead and rebuild with what I have? (I guess I'm asking if there is that much of a difference in the products...) |
Joe Bob, then I need to replace my tranny mounts (recently replaced the engine ones) as I also do feel the feedback in the shifter lever when hitting the throttle.
Thanx, Serg |
RETIRED
Open the inspection cover on the tunnel in front of the back seats. A good visual is needed prior to ordering parts.
Do a search on the coupler R&R.....easy to screw the pooch...... The tranny mounts for nene.....consider WEVO products. Be advised if you go with hard core mounts, you will have harmonic noise in the cabin.
Since I got my '83 SC in 2012, I've replaced the coupler with the Coupler whisperer's bushings, the cup at the base of the shifter, the shift rod bushing, and both hard-as-rock motor and tranny mounts with Wevo blue pillows (the softer ones). I also replaced the clutch cable, it got thrashed when the clevis pin at the pedal snapped. Even with all this and expert shift adjustment to the clutch throw, I still have 1 in ten shifts from neutral to first, and first to second, that are "notchy" or difficult. That said, there is a great improvement from when I got the car and I am glad I did all this!
Va_Powerman:
(insert Homer singing, "I am a lineman for the county.....") You should take a look at the WEVO PSJ if you are going to replace the bushings... my suggestion.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
Cars and Cappuccino
Check the cup on the shifter rod that the end of the shifter inserts into. Mine had come loose and made shifting a nightmare. It was waggling like hell and someone with bigger balls than me welded it back in place. (Those are fuel lines running right next to it) I did all the coupler maintenance first before I figured out it was the actual cup.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Brew Master
I'd say front to back play is the shift coupler with sided to side being the tunnel bushing. I had me tunnel bushing go out recently and it caused a lot of side to side play while in gear. I was also bumping R coming out of 5 down to 4 but that can also be a symptom of worn shift coupler bushings. Replacing is really easy.
1985 WPO ZZZ Targa |
Please keep us posted :-)
There are too many threads about 915 shifter so I don't start a new one but continue on this one instead..
I just replaced the bushings below stick and shifter and replaced the coupler. I adjusted coupler by setting gear to N and then turning coupler all the way to right and stick perpendicular to the shifter and all the way to left. Then tightened the clamp. It seems to shift OK, there is no play (anymore) and I can find all gears. However, I could only test while in park as it is already winter time here in Finland. I read from many sources that there actually SHOULD be some play in coupler when on fifth gear. Why is this? Is it bad if I don't have any? If it is bad, how should I adjust it? http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm "h) ... and lastly, there must be a little bit of rotational play when 5th gear is selected. This is checked by shifting into 5th, and feeling whether you can wiggle the shift coupler with your hand. It should just click back and forth slightly...not much, but clearly discernable play."
Porsche 911 SC Coupe (1982, RoW, Zinnmetallic) Last edited by suckho; 12-05-2014 at 05:38 AM.. |
As everyone has said sounds like the bushings which are a quick fix and well worth it. The other thing that could be causing the wear is old/worn motor mounts. If the mounts have a lot of play the engine will rotate a bit while accelerating. Since the head of the shifter is mounted to the chassis and not floating the same plane as the engine/trans is allowed to move the engine motion will cause the joints (and in turns bushings) to wear out.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Replaced the shifter, tunnel, and coupler bushings, which by all accounts were original (about 87k miles).
With the new pelican coupler bushings the coupler, and shifting, is significantly tightened up (very little play anywhere). Took a short test ride with a cold car and besides a finicky 4th, it seemed to be a significant improvement. Kind of a pain in the butt do do, but nothing too terribly difficult...
Brew Master
Once you get past bushing replacement, any shifting difficulties are mainly due to one's driving or shifting style. If you aren't aware of the weakness of 915 gearboxes, please review the materials/feedback sprinkled throughout Pelican archives. Here's one I suggest, but it involves a higher level of shifting to both extend gearbox life and increase driver skill.
Anyone double clutch on downshifts? Why? Sherwood |
Flex
I just finished installing a Wevo shift kit whit new bushes etc.
Still i notice a flex between the shift tower and the tunnel. I notice the flex in the actual sheet metal of the tunnel. Anybody tried to improve on it? Curious how. |
