| Registered |
				Can't find 4th or 5th gear?
			Took the car out for the first drive since the resto is complete. Engine was rebuilt, tranny taken out but not rebuilt. No history on tranny. I can't seem to be able to shift it into 4th or 5th gear when I am on the road. Any suggestions? Thanks, Derek
				__________________ 1989 964 Carrera 4 Coupe | ||
|  06-10-2005, 09:38 PM |
| Registered Join Date: Dec 2004 Location: Novato, CA
			Either the tranny is blown, or you need to readjust the shift linkage... ianc
				__________________ BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 | ||
|  06-10-2005, 09:45 PM |
| Registered |
			Assuming it is the shift linkage which I would start with as a first step. What would I do with it - move it forward, to the back? I do not recall there being alot of options to adjust the linkage - doesn't the bolt have a pointed tip that goes in to a hole? Thanks, Derek
|  06-10-2005, 10:06 PM |
			You're looking to adjust the side to side motion of the coupler behind the seats under the cover plate. The screw you describe locates the coupler on the transmission shaft, but the coupler is clamped to the shift linkage rod at the other end. Play with this and make sure you have adequate lateral motion to engage 4th and 5th. A search will reveal plenty of material on the mechanics of the adjustment process. ianc
|  06-10-2005, 10:51 PM |
| Registered Join Date: Feb 2004 Location: Houston
			One thing that may be happening is the bushing are worn, I ran in to the same troulbe when I was done my car, I changed the bushing out in the rear coupling and I had all five gears, good luck Derek
				__________________ Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door | ||
|  06-10-2005, 11:03 PM |
| Registered |
			undoubtedly the shift coupler is simply out of adjustment..when the engine and tranny were re-installed they just didn't get it set correctly. there's an art to getting it just right and it may take a couple attempts to get it where you want it. remove the cover in the back floorboard and take the pair of wrenches to loosen coupler. start by moving gear shifter lever all the way to the left and with your right hand, physically move coupler all the way to the right. tighten coupler. now try shifting the gears. from here you may have to loosen again and adjust gear shifter in different points 'up and down' to get it right. good luck. ryan
				__________________ To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) | ||
|  06-10-2005, 11:48 PM |
| Registered |
			Thanks guys, I will try this as soon as I get the wheels back on. I am rebuilding the calipers at the moment.
|  06-11-2005, 08:10 AM |
