Targa rear glass removal
Is there an easy way to remove rear glass in my targa without breaking it??
I just did a glass out respray and I cut the old seal. Once cut the glass lifted right out. Reinstall was a real pain. Need to remove the targa bar cover for reinstallation. Best to use a new seal when you remove the rear glass anyway.
I thought the targa bar might have to come off for installation. Oh well I am getting ready to do a paint job and there's no way I'm gonna spend all that time and not take all the glass out. Did the targa bar come out easily??
Definitely cut the old rubber.
Targa bar is easy. Screws around the front (obscured by the front rubber) and nuts from inside the rear fender right up the top under the lowest point of the targa bar (which will probably break off the captive studs because they are very susceptible to rusting - easy enough to weld replacements back on).
Laurence 1998 Specbox racer / 1998 Boxster / 1984 RSR tribute 1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa 1963 356B T6 Coupe / 1962 356B T6 Cabriolet Current projects - 1955 356 pre-a Speedster / 1964 356C |
Think I got it figured out just gotta be careful with those defroster wire
Thanks guys
