Targa bar help
I have a 1980 sc targa and I need to take the back window out for paint. One member told me I needed to remove targa bar and that's my issue. I removed every screw that I could find and still it won't budge did porsche use adhesive on the cover or what? Or maybe I'm missing something? Please help
there are two nuts you have to remove on each side, and they are accessed through the wheel wells. did you take those off?
Thanks! What are my odds of not snapping those off 100 to 1?
hit them with some pb blaster or similar for a day or two before you try to get them off.
if the car has been in the NE all its life a d seenthe snow alot, then not good. But I got the 30 years old nuts off my Southern call, no problem. Good luck.
I remember them being speed nuts on my 81, like on the hood emblem. But it has been over ten years.
Bob, I think the nuts that hold the bar on were regular nuts and the trim piece under the rubber glass seal (the trim that goes from the bar backwards toward the back of the car) is held on with speed nuts. Both sets of nuts are inside the rear quarter panels.
They are regular nuts and I hit them with pb blaster actually they don't look too bad car was from Virginia. I got a lot of work to do!!
Thanks for the help guys. One thing I noticed is that the interior pieces around the targa top don't seem to be engineered too well a lot of vinyl glued over rubber,metal et. Don't know how I'm gonna get her back to showroom condition, can you still find interior pieces for these targas???
A lot of what I've seen is people having pieces recovered/remade. Like the black vinyl covering the underside of the targa bar, which is apparently a Big Project. Dan Petchel at Cars Inc. can tell you a lot about the top itself.
I do remember those trim pieces appeared to be brass under the black anodizing stuff. Maybe some heavy coating but definitely something you do not see on Honda trim. These cars are pretty slick. Still old school in semi-recent times. |
http://forums.pelicanparts.com/uploa...1425356511.jpg Here is my parts list for targa bar resto/reassembly. I ordered all of the parts to reassemble from Pelican. Part numbers: 901-565-930-41-M260 Targa Bar to Rear Window Beading, 911 (1974-89) 911-565-091-45-M260 Targa Front Bar Seal, 911 (1974-85) 999-591-423-03-M260 Speed Nut for Hood & Decklid Emblems (6) 999-703-186-40-M100 Plastic Rivet/Plug (sold per each, 4 required), 911SC / Turbo (1978-1983) 901-565-361-40-OEM Targa Aligning Seal (sold per each, 2 required), 911 (1974-85) 901-801-153-40-OEM Plastic Screw Plug, sold each (4 required), 911SC / Turbo (1978-1983) (TARGA) 999-591-384-40-OEM Cap for Plastic Rivet/Plug (sold per each, 4 required), 911SC / Turbo (1978-1983) |
Looks great I guess that's the path I will have to take. What kind of cement did you use on the vinyl?
I used dap weldwood on the vinyl to metal and used 3m ultra trim adhesive on the foam to vinyl.
