Targa bar help
I have a 1980 sc targa and I need to take the back window out for paint. One member told me I needed to remove targa bar and that's my issue. I removed every screw that I could find and still it won't budge did porsche use adhesive on the cover or what? Or maybe I'm missing something? Please help
Old 03-02-2015, 12:22 PM
nineball's Avatar
there are two nuts you have to remove on each side, and they are accessed through the wheel wells. did you take those off?
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-02-2015, 12:25 PM
Thanks! What are my odds of not snapping those off 100 to 1?
Old 03-02-2015, 12:53 PM
nineball's Avatar
hit them with some pb blaster or similar for a day or two before you try to get them off.
Old 03-02-2015, 01:04 PM
Cars and Cappuccino
tdw28210's Avatar
if the car has been in the NE all its life a d seenthe snow alot, then not good. But I got the 30 years old nuts off my Southern call, no problem. Good luck.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-02-2015, 02:28 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I remember them being speed nuts on my 81, like on the hood emblem. But it has been over ten years.
1981 911SC Targa
Old 03-02-2015, 04:54 PM
Bob, I think the nuts that hold the bar on were regular nuts and the trim piece under the rubber glass seal (the trim that goes from the bar backwards toward the back of the car) is held on with speed nuts. Both sets of nuts are inside the rear quarter panels.
1985 911 Targa 3.2 with 964 Body Kit
Old 03-02-2015, 05:04 PM
They are regular nuts and I hit them with pb blaster actually they don't look too bad car was from Virginia. I got a lot of work to do!!
Old 03-02-2015, 06:03 PM
Thanks for the help guys. One thing I noticed is that the interior pieces around the targa top don't seem to be engineered too well a lot of vinyl glued over rubber,metal et. Don't know how I'm gonna get her back to showroom condition, can you still find interior pieces for these targas???
Old 03-02-2015, 06:08 PM
universeman's Avatar
A lot of what I've seen is people having pieces recovered/remade. Like the black vinyl covering the underside of the targa bar, which is apparently a Big Project. Dan Petchel at Cars Inc. can tell you a lot about the top itself.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 03-02-2015, 06:33 PM
Bob Kontak's Avatar
Ahhh. Thank you.
I do remember those trim pieces appeared to be brass under the black anodizing stuff. Maybe some heavy coating but definitely something you do not see on Honda trim.
These cars are pretty slick. Still old school in semi-recent times.
1981 911SC Targa
Old 03-02-2015, 06:47 PM
Yes you can! Autos international carries the vinyl you would need. LOTs of dissassembley required to just replace the targa bar vinyl pieces. I recently finished and its a ton of work. I had droopy viny and now it's as good as new! Happy to help if I can.
Here is my parts list for targa bar resto/reassembly.
I ordered all of the parts to reassemble from Pelican.
Part numbers:
901-565-930-41-M260 Targa Bar to Rear Window Beading, 911 (1974-89)
911-565-091-45-M260 Targa Front Bar Seal, 911 (1974-85)
999-591-423-03-M260 Speed Nut for Hood & Decklid Emblems (6)
999-703-186-40-M100 Plastic Rivet/Plug (sold per each, 4 required), 911SC / Turbo (1978-1983)
901-565-361-40-OEM Targa Aligning Seal (sold per each, 2 required), 911 (1974-85)
901-801-153-40-OEM Plastic Screw Plug, sold each (4 required), 911SC / Turbo (1978-1983) (TARGA)
999-591-384-40-OEM Cap for Plastic Rivet/Plug (sold per each, 4 required), 911SC / Turbo (1978-1983)
1982 911 Targa, 3.0L ROW with Webers
Old 03-02-2015, 08:23 PM
Looks great I guess that's the path I will have to take. What kind of cement did you use on the vinyl?
Old 03-03-2015, 05:05 AM
I used dap weldwood on the vinyl to metal and used 3m ultra trim adhesive on the foam to vinyl.
Old 03-03-2015, 05:33 AM
