Weird Electrical Question-Help Needed
Fellow Pelicans,
My 70 911T is having a weird come and go electrical issue. The car sits in the garage most of the week and I drive it on weekends. Lately, when I fire it up for a drive it starts up and I head into our small town on an errand about 5 miles. When I get back in to start it to go home- I get the infamous solenoid click but no start, unless I push start it. Then when I get home I let it sit for a while and it starts like nothing was wrong. It's done it a few times now even after I've let it have a trickle charger on it over night. What gives? Dirty Marty Fallbrook, CA ![]() ![]() |
Common issues for this symptom:
- loose and/or corroded battery connection (either cable) - malfunctioning starter - borderline battery - combination of any of the above Sherwood |
Hi
Can we add starter solenoid to that list?
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
sounds like dirty marty has dirty connections, start with cleaning battery terminals and connectors paying attention to where ground attached to frame , then clean connections at starter
I think that maybe I'm dreaming.. |
Crusty Conservative
try to get someone to do a dynamic test of your battery and charging circuit. Snap-on and others make a tester for this purpose.
My 1970 with an external regulator had symptoms like this, and it turned out to be bad radio supression capacitors attached to the regulators terminals. They can be completely removed and the charging circuit will work just fine. This tip courtesy of Ed Mayo, one of our national gurus..
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Been here a while
Also, the start circuit of the ignition switch can go bad and wouldn't you guess it often works a couple of times but after a couple of starts won't give you another for a while.
Still, I'd say most likely is the starter motor itself/solenoid, etc. you can whack the starter with a hammer when it's misbehavibg. That's as close to a 100% confirmation as you will get. |
The solenoid/bendix must "full travel" in order to supply full 12V power to the starter commutator.
Apparently it isn't when hot. |
Should he measure 12V at the battery to rule out the battery?
Or is this already accepted since it starts the next day.
1986 Bosch Icon Wipers coupe. |
all VERY good advise. start with the simple stuff first.
you can have 12v at the battery/starter but not enough current to pull in the solenoid. it takes a lot of curent to pull in the solenoid. what happens with the solenoid is the contacts inside get burned/corroded and it does not provide the current to the starter motor to turn over. the solenoid can be removed and the contacts cleaned and rotated. only about half of the contact is used so the other half looks like new. the yellow start wire is very long and goes thru several connectors. corrsion at these connections can reduce the current. also, if you have a car alarm they can also cause the same problem
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Thanks to all of you for your advise.......I will start with the simple stuff and go from there.
Dirty Marty Fallbrook,CA ![]() |
You can disassemble the starter solenoid and rebuild the electrical contacts with high temperature (high silver content) solder. See: https://www.youtube.com/watch?v=ITFW2PkqXWw Last edited by wwest; 03-05-2015 at 10:17 AM.. |
Thread Tools | |
Rate This Thread | |
