Cars and Cappuccino
tdw28210's Avatar
'77 Fan upgrade to 11 blades: Which fans work?
Hi,
Been trying to figure this out. I am looking to replace the 5-blade on my '77 S with an 11-blade. There seems to be a few various part numbers that may/may not work. Can anyone share a definitive part number they KNOW works? Like through actually installing it and seeing it work?
And I assume the housing does not need to change, but if I am wrong about that, please let me know. Thanks in advance as always.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 04-07-2015, 05:19 AM
Bill Verburg's Avatar
Originally Posted by tdw28210 View Post
Hi,
you have a 5 blade 245mm fan
you want an 11 blade 245mm fan
best is the '85-89 3.2 fan, it has additional slots to cool the alternator, use w/
next best is the '80-84 SC
last choice is the '66-74 fan
use w/ the stock pulley halves for best effect, 1.8 ratio
Bill Verburg
Old 04-07-2015, 02:22 PM
76 911S Targa
As Bill said, use the original pulley set up to get the most cooling from your new eleven blade fan. The 1.8 ratio with the eleven blade fan gives the highest airflow of any pulley set up. You will love the sound. Compared to the five blade fan it sounds like a low flying jet aircraft.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-07-2015, 02:40 PM
Cars and Cappuccino
tdw28210's Avatar
Thanks Bill. Thanks Targalid.
Old 04-07-2015, 04:21 PM
Location: behind the redwood curtain, (humboldt county) california
How much benefit to upgrading a 74 to an 85??
If the 74 is the last option, does that mean that an "upgrade" from a 74 to an 85 11 blade fan would improve the airflow on the 74???
Is it enough to be worth doing???
chris
Old 04-07-2015, 04:41 PM
80 through Carrera with the small holes in the pulley halves. With the 77 crank pulley you'll need the 9.5 x 725 belt.
Bruce
Old 04-07-2015, 05:33 PM
